Results 1 to 13 of 13
Thread: Santro Club missing on petrol
    IHateRollas's Avatar
    Jul 2011
    475
    Default Santro Club missing on petrol
    Car in question is Hyundai Santro Club
    The car is running fine on CNG. On petrol, the RPM was going up and down in idle position and the car was not responsive at all. On CNG it was good. I showed it to mechanic, he said one of ur injector is not working so we have to change it. He changed 2 injectors but no use.. After the long hard work he was not able to diagnose the problem.. I came back home, pulled out my tool box and removed the throttle body and IACV and cleaned it thruoghly with carb cleaner. Put back all the things, started the car and the RPM problem was gone and the RPM was stable.. Now the problem which remains is the missing problem. Car is missing on petrol and there is a smell of urburnt petrol. What could be the problem ??? Need help...
    Jul 2011
    475
    urgently help needed
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    Check fuel pressure and also replace fuel filter it might be clogged.
    Never loose hope in life,every step gives u something.
    Jul 2011
    475
    Problem Solved !!!
    MiniAkcent10's Avatar
    May 2013
    Faisalabad
    19
    160
    3 Post(s)
    Bro,i had the same problem... i changed the fuel pump
    m.yousaf789's Avatar
    Jul 2013
    33
    bro i am facing the same problemm.. did u change the fuel pump or fuel filter,,
    is the fuel pump one which is fitted on the top of petrol tank underneath the back seat???
    in how much did u gt the fuel pump replaced??
    Quote Originally Posted by MiniAkcent10 View Post
    Jul 2013
    33
    nro guide me how the problem is solved???
    what did you do??
    m planning to change fueel filter and gettin feul injectors serviced..
    Quote Originally Posted by IHateRollas View Post
    Problem Solved !!!
    Jul 2013
    33
    suggestions bro??
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    if cylinders 2 and 3 are not firing on petrol then replace the cam sensor.
    Jul 2013
    33
    please elaborate bro..
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    btw - did you connect an OBD scanner (not reader) to your car?
  12. #12
    Jul 2013
    33
    Yeah. The hyundai motors mechanic placed a device under the setring to scan the car for errors n there was none.
    Sent from my iPhone using PW Forums mobile app
  13. #13
    May 2013
    Faisalabad
    19
    160
    3 Post(s)
    Quote Originally Posted by m.yousaf789 View Post
    I changed the fuel pump.. it worked good for 2-3 months but after that im again having the same problem
