Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
Thread: Tyers for santro
    ssilverwings4's Avatar
    Feb 2013
    30
  2. #21
    VDR6367's Avatar
    Jul 2013
    48
    if changing only 2 install it at front... max weight is at front and those are the tires which get worn out soon and regular practice who drive alone to work and home rotate tires back to front and front to back after some 25k kms because due to less weight the rear once will have more thread than front...
    if you are doing only 2 then install it on the front bro
  3. #22
    Feb 2013
    30
    i already have the 170/55 tires.i dun need to buy this size.so there is no harm in using 2 different types of tyres i-e 155/70 at the front and 170/55 at rear else having bad fuel economy.am i rite?this practice is also temporary (un-availability of tyres) Any suggestions plz.
  4. #23
    khm42747's Avatar
    Jan 2013
    1,340
    43 Post(s)
    2 Thread(s)
    Quote Originally Posted by ssilverwings4 View Post
    No it won't hurt the fuel economy.
    If u have 4 tyres of the same size than go for all four because the 175 55 r13 is 1.2 cm smaller in height so it would be better that u have all four or if u don't then change ur tyres as soon as possible.
    Sent from my GT-N7100 using PW Forums mobile app
    Don't Compromise Because So Much Is Riding On Your TYRES.So Be SAFE and Choose Wisely.
