Results 1 to 3 of 3
Thread: Problem with my intank fuel pump....
    asadullah786's Avatar
    Nov 2007
    20
    Default Problem with my intank fuel pump....
    Hello everyone....I own a 96 Kia Sportage....It was on diesel....I convert it to CNG, every thing was fine, engine was great and suddenly I found that my in-tank fuel pump loose pressure every 3 months....means I have to change it....or 5500 every 3 months.....
    My question is.... is there any difference in the inner part of fuel tank between diesel and petrol .....I found so much rust in my tank, which spoils the pump... its not the normal life cycle of a pump....what is wrong with it.....
    Any help and suggestion will be highly appreciated...
    Regards
    Asadullah
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    you already know your problem, clean the tank and keep fresh petrol in it.
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    Add cut off relay in ur system which switch off pump while the car is on CNG this will incease pump life
    Sent from my GT-I9105 using PW Forums mobile app
Tags for this Thread
