Results 1 to 5 of 5
Thread: Santro Ac problem
    digitalmohsin's Avatar
    Aug 2009
    27
    1,350
    12 Post(s)
    Default Santro Ac problem
    Hi all,
    i recently bought a 2007 model santro club gv. when i bought it its ac was not in working condition. previous owner told me that its compressor has fried. nonetheless i bought it and took it to an ac wala and got ac working. the ac wala said that this is original compressor and its fine but he found that condenser was ruptured from below which he repaired and fixed the ac.
    now the problem is that airflow from vents is very low. also car doesn't cool when standing still and in sunlight the cooling is non existent even in these days when summer is almost gone. but when i drive car at speed above 50 km/h then ac starts cooling fine however air flow from vents remains the same.
    what could cause this problem? kindly help.
    20GB Free Online Storage: Sign-up Now: https://copy.com?r=CPom47
    danish.ijaz.754's Avatar
    Feb 2013
    27
    24
    get your cooling coil cleaned.. simply service it and also clean all ducts because some times broken ducks cause air flow problem. you will need to open dash board also for this
    dr3vil's Avatar
    May 2009
    11,929
    11
    201 Post(s)
    7 Thread(s)
    Quote Originally Posted by digitalmohsin View Post
    Hi all,
    i was having similar issues with alto
    and culprit was condenser which had a microscopic leak
    and cooling coil needs service
    Hanjiii Kaa Storeey Eehh !
    jah
    jah is offline
    jah's Avatar
    Oct 2005
    28
    236
    I had the same issue in my Santro (2004). The condenser was to be blamed and know it has been 3 years, works like a charm!
    Aug 2009
    27
    1,350
    12 Post(s)
    Quote Originally Posted by danish.ijaz.754 View Post
    will gas be needed to refilled after cooling coil cleaning?
