Results 1 to 13 of 13
Like Tree2Likes
  • 1 Post By metalhead
  • 1 Post By spectra
Thread: Spectra fresh air
    ch_ahmed's Avatar
    Mar 2014
    214
    Default Spectra fresh air
    can somebody tell me where this mechanism located or how this work in kia spectra 2001 model fresh air/recirculation.... so by the help i could run it again.
    .Spectra fresh air -1536671
    ch_ahmed's Avatar
    Mar 2014
    214
    anyone
    metalhead's Avatar
    Oct 2006
    Wah cantt
    1,301
    49 Post(s)
    I believe your fresh air intake is not working and you want to correct it and use it. Please clarify your query. The picture is also too dark. Is it an electrical push button like in civic or mechanical one.
    it takes fresh air from outside through a cabin filter.
    ch_ahmed's Avatar
    Mar 2014
    214
    Quote Originally Posted by metalhead View Post
    first of all thanks for reply.....yes u understand right i want to correct this into working condition this is electric switch first it is running but after going to electrician for other work this is not working he remove the connector but now we do not know where to find the actuator or connector plz suggest
    hash4u's Avatar
    May 2005
    38
    24,363
    18
    404 Post(s)
    13 Thread(s)
    13
    so he fixed 1 thing
    and ruined another
    typical mechanic sadly .....and now he has no clue how to fix it back
    go to some electrician who knows how to work properly
    metalhead's Avatar
    Oct 2006
    Wah cantt
    1,301
    49 Post(s)
    He want to do it himself... the electrician may have forgot to reconnect it...
    You should be looking four the vane and actuator before the blower motor. There will be an intake before the blower for inside air. Look four a vane controlled by a small motor just before that intake under dash.
    metalhead's Avatar
    Oct 2006
    Wah cantt
    1,301
    49 Post(s)
    Usually the AC electricians block that fresh air toggle vane with foam to avoid sucking warm outside air....
    ch_ahmed's Avatar
    Mar 2014
    214
    @hash4u @metalhead can u plz tell me the exact location iam unable to find it near blower motor i don not find any connector position
    hash4u's Avatar
    May 2005
    38
    24,363
    18
    404 Post(s)
    13 Thread(s)
    13
    @spectra
    can u help guide here
    ch_ahmed's Avatar
    Mar 2014
    214
    i found it near the front passenger door i will post pics in sometime but now another struggle start for finding the connector electrician also cut some wires...searching mode on!!...........
    metalhead's Avatar
    Oct 2006
    Wah cantt
    1,301
    49 Post(s)
    Why not take it to the same electrician. He should be asked for what he did...
  12. #12
    ch_ahmed's Avatar
    Mar 2014
    214
    us ullo......... ko samjh aye to na
  13. #13
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    23 Thread(s)
    I Never opened up these parts so i wont be able to tell you what to do where. Although i think if u take the glove box off and you should be bale to see the mechanism. From there you can track wiring going towards switch.
    Keep a cool head and wear seatbelts!
