Results 1 to 4 of 4
Thread: Hyundai Santro Brake problem
    alikhan915's Avatar
    Feb 2013
    Peshawar
    7
    Default Hyundai Santro Brake problem
    Salam members! I own a hyundai santro 2000. Wanted to get your opinions about the brake problem.The brake has failed 2 times till now,thanks to Allah, I wasn't at high speed at both incidents Brake failed because the left wheel brake pipe burst both the times. And that's because what I believe the brake system of the right wheel doesn't work properly. Whenever I have to apply brake in emergency, the left wheel instantly stops,infact skids, but the right one doesn't stop.I showed it to different mechanics but they just changed the brake pipes,saying the santro brake pipes are local made and now both side brakes are working with alto brake pipes(kabuli)But the problem is still there. Now I'm planning to go to a mechanic someday and tell him to open the right side brake system and wash it with petrol or do whatever he has to and make it working.Waiting for your suggestions..
    alikhan915's Avatar
    Feb 2013
    Peshawar
    7
    Plus! the mechanics also say that brake lathers are also good(no need to change)
    hash4u's Avatar
    May 2005
    38
    24,366
    18
    404 Post(s)
    13 Thread(s)
    13
    they inspect the callipers?master cylinder?brake T? one tyre locking up only means car can go out of control easilly.dangerous and should be fixed with priority
    alikhan915's Avatar
    Feb 2013
    Peshawar
    7
    Quote Originally Posted by hash4u View Post
    hash4u thank u sir!
    I'll make sure he checks these things this time u mentioned above
