Results 1 to 4 of 4
Thread: Santro steering tight, won't return to center
    bells's Avatar
    Apr 2010
    34
    8
    Default Santro steering tight, won't return to center
    I just had replaced my Santro Club's front right hub barring and the ball joints on both sides. Took the car home and while driving I noticed that the steering wheel is tight and just stays where I leave it and it does not return back to center automatically. I had to take it back to center manually to align straight on the road.
    Is it related to the parts I just got replaced e.g the ball joints? Or it could be something else...
    Thank you
    saeedmagsi's Avatar
    Nov 2011
    Quetta
    229
    34 Post(s)
    It needs wheel alignment
    bells's Avatar
    Apr 2010
    34
    8
    Sorry. I didn't mention. I took it to wheel alignment first when he told to get the ball joints replaced. After getting the ball joints replaced, I also got the wheel alignment done..
    Proverbial_Slang's Avatar
    May 2005
    3,906
    29 Post(s)
    The suspension parts have been tightened too much and at wrong angles. The ball joint if repaired act like this as it is basically a jugaarr.
    The suspension needs to be tightened with the wheels at resting position.
    Death is not the greatest loss in life. The greatest loss is what dies inside us while we live.
