Results 1 to 4 of 4
Thread: wanted to increase shock absorber spring length
    ch_ahmed's Avatar
    Mar 2014
    214
    Default wanted to increase shock absorber spring length
    iam wanted to increase length of spring/coil of rear shocks, because of load (weight) on my kia spectra and bumpy road conditions, soo kindly tell me harms and goods.
    Click here for SOLUTION
    Similar Threads:
    ch_ahmed's Avatar
    Mar 2014
    214
    any one
    sufian_noshad's Avatar
    Mar 2006
    Rawalpindi
    31
    219
    5 Post(s)
    Nothing good about increasing the shock length my friend apart from road clearance and probably be a bit more comfier as there's more suspension travel. Negatives there's a lot. Main one being affecting the suspension geometry which has an adverse effect on all the suspension related components like bushes links joint anti roll bar etc as you want to raise the rear suspension there's not all of them components involved but still there is some bushes etc anyway in desi engineering we use some aluminium blocks between the spring and the body to increase its length which is called packing.
    Dnt forget to have your wheel alignment done after doing so.
    ch_ahmed's Avatar
    Mar 2014
    214
    Thanks SUFIAN
