Results 1 to 3 of 3
Thread: Gear Problem after Gear Oil Change - Santro 2008
    rev2008's Avatar
    May 2014
    39
    Default Gear Problem after Gear Oil Change - Santro 2008
    My Santro Prime 2008's Gear was getting a little hard but working perfectly fine so i decided to get the oil changed.
    I wen to Shell Pump situated near Millenium Mall Karachi, (They have a workshop where people wait in queue to get things changed so they know what they are doing) and asked them to change it they charged me approx Rs. 1500 and changed it.
    Now the gears are soft and are working perfect while car is standing but many times the second gear make noise and get a bit stucked while shifting when car is going above 20-30 Speed
    Please guide experts what can be the problem?
    faizanali's Avatar
    Jan 2007
    35
    782
    11 Post(s)
    Get your gear lever bushes rubber checked
    In my case it was faulty and total repair cost was 1000 only
    rev2008's Avatar
    May 2014
    39
    Quote Originally Posted by faizanali View Post
    Mechanic said Pressure and Clutch plates along with Clutch Cable are gone
    Engine needs to be removed for replacing those as these cannot be replaced without removing engine in Santro
    so its a long process
    This is the estimate that he has given me:
    All Saman around 4500
    Labour 3000
    500 for some adjustment of something i don't know
    So Total Approx 8k
