Results 1 to 3 of 3
Thread: MY SANTRO PLUS
    km2000's Avatar
    Oct 2006
    43
    Default MY SANTRO PLUS
    1. I HAVE A RELATIVELY COMPLEX PROBLEM WITH BOTH CNG & PETROL DRIVE. DURING THE DRIVE MY CAR OFTEN GET ELECTRIC SURGES AND MISSES THE ENGINE. THE POWER GETS OFF INTERMITENTLY LIKE IT HAS SOME LOOSE ELECTRIC CONNECTION. IVE GOT ALL CONNECTIONS CHECKED AND MECH SAYS ITS OK.
    2. OTHER PROBLEM IS THAT THE AIR FILTER BOX GET OVER PRESSURIZED AND OPENS AUTO WITH A BANG.
    3. I HAVE A LANDI RENZO KIT WITHOUT ADVANCER & EMULATOR SO WHILE DRIVEING ON AC THE AC TRIPS WHILE IDELING BECAUSE ON LESS RPM
    4, HOW MUCH IT WILL COST ME AT SHAN CNG FOR GETTING EVETY THING DONE
    CAN ANY ONE GUIDE ME AND INDICATE A MECH IN ISLAMABAD
    mukhtar_ali's Avatar
    Jan 2006
    43
    139
    First of all check battery terminals as if they are lose car would be totally dead even after starting and working on generator if battery disconnects car will turn off. Clean the terminals with sand paper, apply little grease to it and fix them back tightly.
    Secondly i think air filter opens with bang due to Back Fire. That means timing is not set. get it adjusted from 3S dealer.
    Thirdly Zetronics adv + emmulator would cost you about 5 K including other small items. You would also need to change Switch which costs about 2200 to 2800 Rs. remember to buy M096 model.. never go for M 094 as it may need alteration. You may also go for zetronics digital meter and switch. It is little costlier but new tech in market. You may slightly increase the GAS supply and your AC would stop tripping.
    BTW without emmulator running SANTRO on GAS is just humiliating
    FX86 =>Mehran98=>Santro03=>Baleno04=>City07=>Xli05
    86-01=> 01-04 => 04=07 =>07=08 =>08-11 =>11
    km2000's Avatar
    Oct 2006
    43
    thnx alot for the advice, the next thing on my budget will be advancer & emulator.
    one thing more can any pnr tell the best place and good rates also in islamabad
