Results 1 to 2 of 2
Thread: Fan Button Issue - is not opening
    rev2008's Avatar
    May 2014
    39
    Default Fan Button Issue - is not opening
    Hello guys i have Santro Prime 2008. The fan button (which we rotate to set fan speed and turn it on) is not working on the point where we have "Maximum fan Speed". All other points are working fine.
    I visited electrician he opened whole thing but was not able to Detach the fan button from the panel so he fixed it back.
    He said due to heat the button has stuck some where and if we will try to detach it forcefully the panel may break. He was totally a noob.
    Do you have some experience with that? Any person who can fix or change it without breaking the panel?
    tintin1's Avatar
    Jan 2014
    1,851
    8
    61 Post(s)
    2 Thread(s)
    8
    5
    i know a guy in Lahore who can fix such issues very efficiently.
    but you are from Karachi....
    anyway you may try to check it with other electricians too. But they give the same answer, then find the whole panel from junk market at cheap price and fix it.
    Be Addicted To Help Others.
