Results 1 to 5 of 5
Thread: Santro Mileage / new software
    malijawed's Avatar
    May 2005
    38
    Default Santro Mileage / new software
    My Santro was doing ( 11.5 to 12 km per litre ) with AC last summer but this time around it is only averaging 10.2 km / litre. I have a clean airfilter, fuel filter, the car was recently tuned, the injector scan etc everything is fine as the mechanics say. I have also upgraded the efi power improvement software but my Santro's milage per litre is not improving any suggestions?? Santro users please post your car's milage
    sali2002's Avatar
    Feb 2005
    30
    1,077
    hello!
    yaar this is mostly the problem with all of us...we have our cars tuned buy y they give bad milage...so its a simple thing that from where ur getting petrol .....the are doing games with u...so change 3 or 4 petrol pumps and feel the difference...also check out ur car plugs buff them ,check tyre air pressure adjust it with proper guage...so this can definately work...
    Thanxxx
    raheel1137's Avatar
    May 2005
    35
    28
    ok the best thing u can do with ur the mileage is when u fill ur tank up with Premier or Super.. just put 5 or 6 litres of Hi-octane.. and get ur spark plugs properly adjusted... I use dto get 10 11 mileage on ma santro when i bought ity.. then someone told me about thsi and after that i'm getting 13 13.5 km with AC... and yes if ur using the original tyre size then dont cross or decrease ur tyre pressure than 28Lbs. i've installed 185 tyres and i keep the pressure between 26 to 28... baki sab set hai... u'l feel the diff..
    Wolf in a Sheep Skin
    bilalahsan's Avatar
    Dec 2004
    46
    459
    6 Post(s)
    Check your Sensors,
    Oxygen Sensor Specially
    sali2002's Avatar
    Feb 2005
    30
    1,077
    hello!
    always use companys recommended tyres...if u go for larger ones...u looses ur milage....it consumes more fuel....
    so check that all definately...this all works.....and hi octane ratio will be 4:1 it will work...
    Thanxx
