Page 140 of 250 FirstFirst ... 4090130138139140141142150190240 ... LastLast
Results 2,781 to 2,800 of 4984
Like Tree536Likes
Thread: Hyundai Santro Fan Club
    u4usman4u's Avatar
    Apr 2006
    32
    4,873
    2 Post(s)
    Default Hyundai Santro Fan Club
    AOA. This part is purely dedicated to HYUNDAI SANTRO which is available in variants. Share ur experience here. Hyundai Santro Fan Club -502667
  2. #2781
    rizkhan2010's Avatar
    Oct 2011
    37
    1,858
    20 Post(s)
    7 Thread(s)
    @nifii ...I n Rawalpindi you can search the following for genuine parts:
    1) autostores outside Kamran Market...and inside Azhar Shaheed Market. ..both on Kashmir road- Saddar Rawalpindi.
    2) autostores in Gawalmandi (Raja bazar-Rawalpindi)
    3) Hyundai Sowan Motors....near Sowaan adda/Total Petrol Pump on G.T Road Rawalpindi
    an important suggestion:
    try to find a mechanic /workshop that is near to your auto-parts supplies. Otherwise if the workshop is far away from your parts supplier....you will have to make unnecessary trips in between the two.
  3. #2782
    sgg1983's Avatar
    Nov 2012
    126
    5 Post(s)
    I'm trying to find the manufacturer, model/Number of the front OEM shocks and where to search... help... help...
  4. #2783
    smartdevil_striker's Avatar
    Dec 2006
    30
    3,359
    8
    109 Post(s)
    2 Thread(s)
    Iridium plugs available for Hyndai Santro....
    Platinum&Iridium Plugs,Performance 8MM Wires,Automotive Bulbs and Bosch Horns for sale Contact: 0333-3035482
  5. #2784
    Oct 2011
    37
    1,858
    20 Post(s)
    7 Thread(s)
    Quote Originally Posted by sgg1983 View Post
    check the places i mentioned above.
  6. #2785
    nifiii's Avatar
    Jun 2013
    25
    133
    2 Post(s)
    Quote Originally Posted by jagger View Post
    bro if still one spark plug is not passing current out of your four... than check your head gasket. sometimes on long tours without coming in our knowledge the car gets heated up.. because of which the head gasket twists as a result of which pressure coming from the head to the spark plug is reduced (spark plug present at that point where there's a twist, so it stops passing current)
    Yes the car's temp gauge's needle got quite a bit right to the centre position(where it is at most of the times,between the two dots). I'll have the head gasket checked the first thing when i get time. I hope it will work. Will keep u updated. Thanks
    Ramazan Mubarik!
  7. #2786
    Oct 2011
    37
    1,858
    20 Post(s)
    7 Thread(s)
    hey...Santro guys....can anyone tell me the EXACT coolant capacity of a santro club ??
    Today i flushed radiator fluid and filled it with new fluid....it took approx 3.75 liters of coolant.
    please respond those who know about the volume /capacity of stock set-up.
  8. #2787
    sgg1983's Avatar
    Nov 2012
    126
    5 Post(s)
    Should b 6L in total.
    Quote Originally Posted by rizkhan2010 View Post
  9. #2788
    sgg1983's Avatar
    Nov 2012
    126
    5 Post(s)
    I heard some where that Santro engine consumes engine oil in routine and reduction is like 0.5L to 1L per 1,500 - 2,000 kms. Is that correct? I changed oil and after 1,800kms 3/4th is left.
  10. #2789
    sgg1983's Avatar
    Nov 2012
    126
    5 Post(s)
    Default Engine oil consumption
    Check this
    Hyundai Santro Fan Club -1228209
  11. #2790
    Oct 2011
    37
    1,858
    20 Post(s)
    7 Thread(s)
    NO WAY...!!!! The actual volume must be somewhere between 3.5 and 4 liters.... in any case its not a drop more than 4 liter.
  12. #2791
    umerjee's Avatar
    May 2012
    72
    perhaps, radiator+expansion tank= 4.5 liter
  13. #2792
    sgg1983's Avatar
    Nov 2012
    126
    5 Post(s)
    Its 4.5L confirmed from the manual.. see image in above post....last line
  14. #2793
    jagger's Avatar
    Jul 2012
    383
    are you including the reservoir bottle as well in 3.75 L???
    coz my setup was filled in 3.5L along with the reservoir bottle
  15. #2794
    jagger's Avatar
    Jul 2012
    383
    coz ur engine rings are worn out bro
  16. #2795
    sgg1983's Avatar
    Nov 2012
    126
    5 Post(s)
    See the manual extract above, five posts earlier........ Engine Oil Consumption.... Normal Driving Conditions Max 1L/1500Km
  17. #2796
    Oct 2011
    37
    1,858
    20 Post(s)
    7 Thread(s)
    yup...the radiator guy filled ...rather overfilled the plastic reservoir bottle beyond the FULL mark. Hence the extra 0.25 liter.
  18. #2797
    Nauman32's Avatar
    Jul 2012
    Faisalabad
    26
    206
    Question Hyundai Santro
    My Hyundai Santro Plus 2002 Has Broken Wind-screen from the left side (not the driver's side)
    Broken Here i mean the scratches but it comes from left to Middle
    I am thinking to replace it
    Some people say don't get it replace until it fell down itself
    But i want to change it
    it seems bad
    I met A Person who had Imported used cars (Santro)
    He is saying he will give me for R.S 8000/-
    The Other Simple Wind Screen Shop I went
    He Said he will be me for R.S 3500 to R.S 4000/-
    * it will be not genuine but he is giving guarantee
    Which one Should I Buy ?
    Please Help
    I am confused
  19. #2798
    sgg1983's Avatar
    Nov 2012
    126
    5 Post(s)
    Buy genuine product... and wind screen is an important part...don't compromise.
    Quote Originally Posted by Nauman32 View Post
    it seems bad
    Please Help
    I am confused
  20. #2799
    sgg1983's Avatar
    Nov 2012
    126
    5 Post(s)
    Recommended coolant for Santro "ethylene glycol based" is ZIC Super A which is pre-diluted and you need 4.5 liter. 1 Liter is Rs.380
    Any one tried?
  21. #2800
    Nauman32's Avatar
    Jul 2012
    Faisalabad
    26
    206
    I am Told that 3500 wale mein b protective sheet hote hay
    So it will not Shatter so easily
    I am confused
    but 8000 is he giving me good price for the genuine one ?
