Page 156 of 250 FirstFirst ... 56106146154155156157158166206 ... LastLast
Results 3,101 to 3,120 of 4987
Like Tree536Likes
Thread: Hyundai Santro Fan Club
    u4usman4u's Avatar
    Apr 2006
    33
    4,873
    2 Post(s)
    Default Hyundai Santro Fan Club
    AOA. This part is purely dedicated to HYUNDAI SANTRO which is available in variants. Share ur experience here. Hyundai Santro Fan Club -502667
  2. #3101
    iamadee's Avatar
    Mar 2008
    41
    1,827
    22 Post(s)
    You have been ripped off then. You must must must get the head gas kit replaced asap....
    That means the history of heatup is even older then that....
    Sharing is caring....
  3. #3102
    zahidbahi's Avatar
    Sep 2013
    104
    Quote Originally Posted by iamadee View Post
    yes you are very right.i really feel depressed and grived when i remember that deal.but one lesson is learnt that dont rely on any body first get you own satisfaction then anything else.anyhow thanks very much brother.
  4. #3103
    syedmohsin2k2's Avatar
    Jan 2009
    31
    66
    Quote Originally Posted by umerjee View Post
    which problem forced u to get the fan direct.
    the car was heating up and the temp sensor wasn't turning the fan on at its preset temperature...
    i thought the gaskit is gone...
    but later on the mechanic changed the fuse/relay in fuse box and the fan started to turn on at preset high temperature and now its working fine...
  5. #3104
    faridahmed's Avatar
    Dec 2012
    163
    2 Post(s)
  6. #3105
    faizanali's Avatar
    Jan 2007
    35
    782
    11 Post(s)
    My car kenwood cd player restart on low rpm, AC on, light dipper and on brake press.. also when I increase sound of cd player.. battery of car is new, original speakers are in use.. it happen mostly at night time when maximum electric things in use.. What is problem.. any idea? and what to do..
  7. #3106
    iamadee's Avatar
    Mar 2008
    41
    1,827
    22 Post(s)
    Quote Originally Posted by faizanali View Post
    Check your stereos wiring and do check for lose ground cable and last but not the least check the battery terminals if they have developed any silt on them.
    Sent from my TCL A909 using Tapatalk 2
  8. #3107
    abart's Avatar
    Jun 2012
    910
    9 Post(s)
    hi friends,
    I have santro 2006 1K driven , around 10 months back i bought it since then i feel that its engine sound is loud as compare to other cars... i asked mechanic to check he said ac compressor will need to check if that is making car sound loud during drive.. he also checked exhaust .. that was fine...
    any suggestion / advise!
  9. #3108
    yadishali's Avatar
    Jun 2012
    21
    I own a Santro Club 2004. From last couple of weeks, its engine find it hard to get sustainable RPM on idle. Car vibrates and so its engine, very visibly on idle. Some times it turns off while idling. However, it is not misfiring. After drive of about 10 to 15 KM when car is hot, it turns off on every traffic signal I stop. And after this, most of the times car do not even starts again on CNG and I have to drive on Petrol.
    I have to keep pressing race paddle to make sure it don't stop.
    I got this car checked from at least 5 different mechanics and every one have its own story such as..
    1- Weak Coil
    2- CNG Wiring Problem
    3- Faulty Fuel Injectors
    4- IAC Valve problem
    All of them did settings and changes but none of them was able to diagnose actual problem :-( I already spent too much on this and in return I am getting nothing.
    I am really looking for some PakWheeler to tell me a good mechanic in Karachi who have Santro's scanner and can fix my car.
  10. #3109
    Jan 2009
    31
    66
    Quote Originally Posted by yadishali View Post
    1- Weak Coil
    Go to hyundai showroom newtown opposite new town police station near AKUH/Liaquat national/civic center
    Ask for Chief Mechanic Norein 0321-2926929, You can give my reference Mohsin of Aga Khan
    For me he is the best
  11. #3110
    iamadee's Avatar
    Mar 2008
    41
    1,827
    22 Post(s)
    Quote Originally Posted by abart View Post
    hi friends,
    Get all the bearings checked I mean compressor bearing timing bearing alternator bearing etc in the engine bay.
  12. #3111
    incognito59's Avatar
    Sep 2006
    57
    3,177
    41 Post(s)
    16 Thread(s)
    I am looking for a Santro for my brother in law. Budget is 4.5 laks.If any one is selling a well kept Santro please PM me, thanks a lot.
    life is but wheels!
  13. #3112
    yadishali's Avatar
    Jun 2012
    21
    Quote Originally Posted by syedmohsin2k2 View Post
    Thank You Mohsin. I will see him soon
  14. #3113
    abart's Avatar
    Jun 2012
    910
    9 Post(s)
    good point regarding bearings..Thanks
  15. #3114
    abart's Avatar
    Jun 2012
    910
    9 Post(s)
    how can we get the condition of valve seal , or how can we know that our santro has weak valve seal?
  16. #3115
    santro-exec.2007's Avatar
    Nov 2013
    8
    Dear All,
    Need expert opinion !!!
    I have santro exec2007 in total genuine condition.. problem is k iska fan direct hai ek bar meinay fan auto kia to gari kuch dair bad heatup hogai although meinay suddenly stop kr k thandi kr k phr fan direct kr k dobara use krna shuru krdi.. n is incident sy iska ek ring n gasket ur gai jo mein replace krwa chuka hun .. and now again i want to auto its fan but confused to what to do ...as mein township hyundai motors bhi gya wo kehtay hain sari wiring dobara check kreingay n ECU ki earth check kreingay 8-9000 Rs ka package suna dia
    also is wja say koi consumption/engine efficieny/fuel economy pay kya farq prta hai /?
    Also mein local city mein ful cylinder mar k 100 kms krta hai n thats y i am missing my coure jo bech k meinay ye tohfa lia hai
    One more advice pls k suba jb mei start krta hu to gas py convert honay k 5-7sec tk ye white smoke deti hai after that it runs normal..instaed 2,3 din say mein isay suba 2,3min petrol pay chlata hun to koi smoke nhi ata n race b normal rehti hai .. Please advice n help me out because meiny comfort dekh k ye gari purchase ki hai esa na ho mughay withdraw krna paray
    Please help !!!
  17. #3116
    Nov 2013
    8
    same yahi masla ho rha hia meray sath n mein apnay ring farigh krwa betha hun.. hyundai walay 7-8 thosand estimate detay hian wt to do ??
  18. #3117
    aqibasit's Avatar
    Apr 2008
    3,178
    30 Post(s)
    2 Thread(s)
    Quote Originally Posted by santro-exec.2007 View Post
    Whats the mileage of car ?
    Body kits available for all cars...
    PM for details
  19. #3118
    aqibasit's Avatar
    Apr 2008
    3,178
    30 Post(s)
    2 Thread(s)
    1- Weak Coil
    Seems a simple problem of CNG tuning to me
    PM for details
  20. #3119
    Nov 2013
    8
    Quote Originally Posted by aqibasit View Post
    Full pressure CNG filling k sath without AC local city mei its doing 100kms hardly
  21. #3120
    Nov 2013
    8
    Please help !!!
