Page 164 of 250 FirstFirst ... 64114154162163164165166174214 ... LastLast
Results 3,261 to 3,280 of 4982
Like Tree536Likes
Thread: Hyundai Santro Fan Club
    u4usman4u's Avatar
    Apr 2006
    32
    4,873
    2 Post(s)
    Default Hyundai Santro Fan Club
    AOA. This part is purely dedicated to HYUNDAI SANTRO which is available in variants. Share ur experience here. Hyundai Santro Fan Club -502667
  2. #3261
    invincible_doc's Avatar
    Sep 2006
    754
    23 Post(s)
    Quote Originally Posted by abart View Post
    Your car is new, you should use synthetic imported brand oil,
    I never heard any repu of shell products here in PK
    Sent from my SM-T211 using PW Forums mobile app
    Thanks for the reply bro. No doubt imported are wow. Thats why I use made in Japan tin pack in my gli. But what guarantee is there that Filter house dha one has real genuine stuff. Someone who has multiple times experience of buying such oils plz help here.
    Sent from my Sony Xperia Z
  3. #3262
    zahidbahi's Avatar
    Sep 2013
    104
    Its possible!
    What model do you have? It depends on your car condition and the way you drive, in which city you drive ?
    I have 2008 santro prime 42 k milage and the city is lahore. whether I drive it good or not dont know about that.Which parts are needed to be tip top for better milage
  4. #3263
    abart's Avatar
    Jun 2012
    909
    9 Post(s)
    Quote Originally Posted by zahidbahi View Post
    Bro you have new car, you should have ideal milage, check computerised fuel adjustment from official hundyai workshop or perhaps you drive on very rush roads thatswhy you are getting the low milage... here in Isb and Rwp roads conditions may be different than your city..I can use forward last 2 gears here in my city!
  5. #3264
    faridahmed's Avatar
    Dec 2012
    160
    2 Post(s)
    Its possible!
    exactly
  6. #3265
    attabros's Avatar
    Feb 2012
    37
    Quote Originally Posted by Horse_rider View Post
    ^^ the automatic fan relay need to be changed, same issue with my friend santro, he changed the relay and now its not going up in slow speed or traffic. my santro is also giving the same problem now a days, I will also change that relay soon I.A.
    i changed the relay but the problem was still there yesterday the mechanic changed the engine coolant temperature sensor & the problem solved now. sensor cost me 600 rupees.
  7. #3266
    attabros's Avatar
    Feb 2012
    37
    Quote Originally Posted by Xplorer View Post
    Solution to Santro's chronic problem is here
    I dont think making both ground common is a good idea ECU ground must be isolated via fuse & by making engine ground & ECU ground common we bypass the fuse , in case of any short circuit caused by any electrical component (battery etc) in a car it will blow the ECU or damage the power supply circuit inside the ECU.
    we should provide the ground connection to the sensor (if there is a bad ground) to make sure the fuse is not bypassed.
  8. #3267
    faridahmed's Avatar
    Dec 2012
    160
    2 Post(s)
    so can anyone tell me capacity of Santro's fuel tank?
    i got 540 in total fill
  9. #3268
    iamadee's Avatar
    Mar 2008
    41
    1,827
    22 Post(s)
    Quote Originally Posted by faridahmed View Post
    Thats an awesome average where do u live in lahore btw...
    Sharing is caring....
  10. #3269
    faridahmed's Avatar
    Dec 2012
    160
    2 Post(s)
    Quote Originally Posted by iamadee View Post
    Saddar. but still any idea on the capacity? i needed to calculate the average
  11. #3270
    iamadee's Avatar
    Mar 2008
    41
    1,827
    22 Post(s)
    No exact idea but maybe some where around 35 litres
    Sent from my TCL A909 using Tapatalk 2
  12. #3271
    Sep 2006
    754
    23 Post(s)
    Hey everyone. How come I saw this brand new applied for Santro from sajjad motors. It was all shiny and New. Is it old stock or New production.
  13. #3272
    faridahmed's Avatar
    Dec 2012
    160
    2 Post(s)
    Quote Originally Posted by invincible_doc View Post
    https://www.pakwheels.com/forums/whe...-santro-lovers
  14. #3273
    harib4u's Avatar
    Dec 2013
    3,436
    6
    113 Post(s)
    Sale purches of santro cars in rwp isb contact me, deal ll done in less then one mint & i also offer you gud price, thanks
  15. #3274
    faizanali's Avatar
    Jan 2007
    35
    782
    11 Post(s)
    Just Calculate my santro 07 fuel avg
    My car done 310 KM in 23 Liter of fuel.. almost 13.5 AVG per Liter
  16. #3275
    maqadir's Avatar
    Jan 2014
    5
    I have santro club 2008 model Lahore registered in 2009. minor scratches .left back door changed. what will be its price.
  17. #3276
    maqadir's Avatar
    Jan 2014
    5
    Quote Originally Posted by harib4u View Post
    I have santro club 2008 model registered in 2009 Lahore no. life time token paid.Minor scratches. left back door is changed. what will be its price.
  18. #3277
    harib4u's Avatar
    Dec 2013
    3,436
    6
    113 Post(s)
    you have a poor mileage
    Quote Originally Posted by faizanali View Post
  19. #3278
    faizanali's Avatar
    Jan 2007
    35
    782
    11 Post(s)
    It will improve if I am not in Lahore Traffic or high way.. I am SURE
  20. #3279
    faizanali's Avatar
    Jan 2007
    35
    782
    11 Post(s)
    Quote Originally Posted by maqadir View Post
    No update? @harib4u
  21. #3280
    Newbie Follow
    knomix's Avatar
    Jan 2014
    you must check Radiator cap inspected , because it has two seals one for in valve and other for outlet
