Page 174 of 250 FirstFirst ... 74124164172173174175176184224 ... LastLast
Results 3,461 to 3,480 of 4984
Like Tree536Likes
Thread: Hyundai Santro Fan Club
    u4usman4u's Avatar
    Apr 2006
    32
    4,873
    2 Post(s)
    Default Hyundai Santro Fan Club
    AOA. This part is purely dedicated to HYUNDAI SANTRO which is available in variants. Share ur experience here. Hyundai Santro Fan Club -502667
  2. #3461
    abart's Avatar
    Jun 2012
    909
    9 Post(s)
    Quote Originally Posted by aqibasit View Post
    Side skirts, spoiler, nice wheels.
    Post the pic so i would advice better
    Already have spoiler, will share photo with you soon
    Sent from my SM-T211 using PW Forums mobile app
  3. #3462
    abart's Avatar
    Jun 2012
    909
    9 Post(s)
    Quote Originally Posted by harib4u View Post
    what about my cars look.
    Mashallah. Very nice, already have seen it, you didn't share tachometer info, is it rpm? How does it work? Can you share its close snapshots. ?
  4. #3463
    aqibasit's Avatar
    Apr 2008
    3,178
    30 Post(s)
    2 Thread(s)
    Quote Originally Posted by abart View Post
    Will be waiting
    Body kits available for all cars...
    PM for details
  5. #3464
    harib4u's Avatar
    Dec 2013
    3,436
    6
    113 Post(s)
    yes its rpm, work fine, first time i see rpm in santro, its fitted by old owner not by me. soon i ll spend some money on it on HIDs, Leds, etc then share some more more pictures there.
  6. #3465
    faizanali's Avatar
    Jan 2007
    35
    782
    11 Post(s)
    Quote Originally Posted by Xplorer View Post
    @ all those facing Santro's heating issue The solution to Santro's chronic heating issue is here This problem is actually because of weak electrical ground to the temperature sensor. It becomes even weaker with time. The solution is to give chassis ground, which is a strong ground, to the sensor. See detailed method by opening above mentioned link. PS: Handle signaling wires with care, wrong connections may fry the ECU
    Bro I did try this one last year on my Santro Club 2007. But Nothing improved..
  7. #3466
    faizanali's Avatar
    Jan 2007
    35
    782
    11 Post(s)
    I don't think making fans direct is a good idea, our desi mechanics are not intelligent more than your car computer chip. Fan will start running when it requires to run to cool down engine. Your car engine need to be warmed for its better performance and long life, removing of thermostat valve is another stupid idea.. if we still feel that radiator fan doesn't start on time and that means something wrong with computer chip... in this case I would suggest to install an automatic switch within radiator to buypass computer chip any good electrician can do this job, this switch reads water temp inside radiator and starts fan when it requires... works pretty nice accordingly!
    It sounds good.. will definitely try this one.
  8. #3467
    abart's Avatar
    Jun 2012
    909
    9 Post(s)
    Will be waiting
    Here are the quick rough shots... which I just taken for you
  9. #3468
    abart's Avatar
    Jun 2012
    909
    9 Post(s)
    Can you tell the maker of this tachometer? I was also looking for something like this... spent 1.5k rs on a universal edition, setted on 4 cylinders settings then found I need tacho of 2 cylinders settings for santro... can you ask the previous owner from where did he buy that rpm?
  10. #3469
    abart's Avatar
    Jun 2012
    909
    9 Post(s)
    Quote Originally Posted by faizanali View Post
    Yes must try and let us know your feedback but keep your fan automatic. I have seen a santro with this fan running technique and owner is happy so far!
  11. #3470
    abart's Avatar
    Jun 2012
    909
    9 Post(s)
    Btw I have 75 watts hid ballast .. they are working perfectly fine... you can try them!
  12. #3471
    aqibasit's Avatar
    Apr 2008
    3,178
    30 Post(s)
    2 Thread(s)
    First of all you need a through detailing.
    Paint the door handles and side mirrors
    Get the windows tinted
    Smoke the headlights
    Side skirts
    & you are good to show
    PM for details
  13. #3472
    abart's Avatar
    Jun 2012
    909
    9 Post(s)
    Side skirts
    Thank you for feedback!
    What color is required for handles and side mirror, isn't black suit well with it?
    And what do you mean by tinting and smoking, putting papers over windows and lights?
    Yar my car already touch ground on some bumpy roads here in isb when I have 2 passengers on back seat, I am afraid having skirts will increase this issue..
  14. #3473
    harib4u's Avatar
    Dec 2013
    3,436
    6
    113 Post(s)
    bachni hai ?
    mine is multitasking rpm, water temp, oil temp, battery gauge, lite on off dim option, gear shift option lite, yes i ll ask old owner then inform you.
    can they ll fit in fog lamps.
  15. #3474
    abart's Avatar
    Jun 2012
    909
    9 Post(s)
    bachni hai ?
    Haha.. naheen yar ..sale krni hute tu itna khyal kiun rakhta
    So all options in tachometer are working fine?oil, battery etc...?
    I got them for fog light as well but they will burn fog tubes if you want to install hid in fog lamps use around 40 to 45 watt ballast..75 watt is good for headlights
  16. #3475
    aqibasit's Avatar
    Apr 2008
    3,178
    30 Post(s)
    2 Thread(s)
    Same as body color
    Tinting means applying tint paper to windows (see the back windows of my ride)
    For smoked headlights see below image:
    Hyundai Santro Fan Club -1399866
    Skirts have nothing to do with touching the ground.
    PM for details
  17. #3476
    faizanali's Avatar
    Jan 2007
    35
    782
    11 Post(s)
    Last Day one of my office fellows Santro had an accident while going Lahore from Sialkot, by Aimen abad road, near Ladher Chowk
    It was 2005 model Santro and it was on 110kmph. A child 2-3 years old suddenly appear crossing road.. he pressed the break and change the direction, child was saved but car hit on a Wapda poll beside the road and Santro rolled on road twice and fell into Wheat crop. My office fellow younger brother was driving and his mother was sitting beside. By the grace of Allah almighty both were saved with minor injuries.
    The roof of car was pressed, front screen / side windows front side broken, but due to wide space and good build material quality saved both of them from serious injuries.
    My Office fellow didn't take pictures of the car, I have request him to provide, car is now moved to Sailkot city for Denting painting work.
  18. #3477
    Newbie Follow
    hasnainali_786's Avatar
    Mar 2012
    SAlam, I Need Santro Head lights and Side mirrors Original ......... do you have any idea from where i can get ?????????? or any one here who want to sale ............
  19. #3478
    abart's Avatar
    Jun 2012
    909
    9 Post(s)
    Allah sab ko mehfoz rakhay.. Amin
  20. #3479
    harib4u's Avatar
    Dec 2013
    3,436
    6
    113 Post(s)
  21. #3480
    abart's Avatar
    Jun 2012
    909
    9 Post(s)
    Same as body color
    Brother, can I get santro side skirts here in islamabad, rawalpindi? What should be its price
