Page 226 of 250 FirstFirst ... 126176216224225226227228236 ... LastLast
Results 4,501 to 4,520 of 4982
Like Tree536Likes
Thread: Hyundai Santro Fan Club
    u4usman4u's Avatar
    Apr 2006
    32
    4,873
    2 Post(s)
    Default Hyundai Santro Fan Club
    AOA. This part is purely dedicated to HYUNDAI SANTRO which is available in variants. Share ur experience here. Hyundai Santro Fan Club -502667
  2. #4501
    Horse_rider's Avatar
    Sep 2009
    30
    1,363
    3 Post(s)
    Quote Originally Posted by zahidbahi View Post
    sir plz share which problems really forced u for overhaul.
    My car was driven 231,121 kms when it reached for overhaul, it was the first full overhaul in its life, the problem was reducing engine oil, smoking, and burning spark plugs of cylinder 2 and 4, later spark plug adaptors were installed to make the car in running condition for a while till overhaul.
    Sent from my GT-I8552 using Tapatalk
    현대 애인
  3. #4502
    Sep 2009
    30
    1,363
    3 Post(s)
    Quote Originally Posted by engrfarrukh View Post
    Dear
    I am also the owner of hyundai santro
    i have a query for you.
    brother i want to overhaul my engine and need a good mechanic in rwp/isb.
    As my car goes above 60, i heard tik tik sound from engine,
    recently tightened that tappet, but still m getting these sounds.
    mechanic told me that this sound in coming from crankshaft.
    need a technical advice in this case.
    Should i go for a complete engine overhaul as my car gives white smoke in first start of car and the rest of the day its normal. never heats up even with the ac on.
    help needed.
    How much your car is totally driven? First get compression test, which will tell you either cylinder or head problems, i.e. rings, piston, valve and valve seals. So first diagnose the problem. Usually little driven under 100k kms car giving white smoke at startups related to valve seals problem, while thick blue smoke indicates rings problem it relates to a higher mileage car usually.
    현대 애인
  4. #4503
    abid110's Avatar
    Jan 2014
    3,884
    90 Post(s)
    Quote Originally Posted by nagar1 View Post
    Earlier when car used to run on cng used yellow cng wala now mostly red...sorry i dont know much abour grades :-(
    red is 20/50
  5. #4504
    Newbie Follow
    zab987's Avatar
    Apr 2009
    Gujranwala
    46
    AOA, I am Santro Owner Model 2006, my vehicle's engine is reducing oil, but there is no smoke found. i have checked from one or two mechanics in lahore , they are saying Connecting rod(awaz kar gaya hai ). now what is the solution. please tell me the best MEchanic of Hyundai Santro in Lahore with contatc number.
  6. #4505
    engrfarrukh's Avatar
    Oct 2011
    Attock
    Car is driven 170K,
    where can i get the compression test in Rwp / Isb
  7. #4506
    sasha11's Avatar
    Nov 2014
    45
    Aoa.Guys my santro club started to vibrate only in second gear rapidly.gear stick and car floor vibrates but steering wheel remains steady.
    Kindly help.
  8. #4507
    iiqbal's Avatar
    Nov 2006
    38
    2,121
    2 Post(s)
    First time around 10 year , Santro gave me problem on road and that was too broken timing belt
    First timing belt change on 70 K km , Now meter reading is 110 k , I have plan to change around 120 k or 130 k. But on Sunday while deriving on slow speed car stop and later diagnose timing belt was broken
    Never got any problem in past , never spend single peny except (Oil Change, Engine Tunning )
    Imran Iqbal
  9. #4508
    abid110's Avatar
    Jan 2014
    3,884
    90 Post(s)
    Quote Originally Posted by iiqbal View Post
    a friend of mine bought an exec in 2007 for 689k... brand new...done over 100k km and has said its ac is still running on factory filled gas - just once issue of clutch came..
    its so bad to see such a good car discontinued in paki!
  10. #4509
    zahidbahi's Avatar
    Sep 2013
    104
    you must be a vary luky man
  11. #4510
    iiqbal's Avatar
    Nov 2006
    38
    2,121
    2 Post(s)
    Thanks God I am Muslim so lucky person on earth. But how I am lucky in this case. Car belt broken well before its expiry . and now have to change valve etc
    Imran Iqbal
  12. #4511
    iiqbal's Avatar
    Nov 2006
    38
    2,121
    2 Post(s)
    Quote Originally Posted by abid110 View Post
    Yes its sad part
  13. #4512
    aqibasit's Avatar
    Apr 2008
    3,178
    30 Post(s)
    2 Thread(s)
    Proud owner of Santro Club 2003 model. Firsts owner till date. Truly its a great car, much much reliable than other rivals. No major work done till now except for regular maintenance. Engine still going strong and powerful. It has never let me down...
    Body kits available for all cars...
    PM for details
  14. #4513
    abid110's Avatar
    Jan 2014
    3,884
    90 Post(s)
    Quote Originally Posted by aqibasit View Post
    that is great. i too want to own one if i get a good maintenance free car in budget
  15. #4514
    aqibasit's Avatar
    Apr 2008
    3,178
    30 Post(s)
    2 Thread(s)
    Santro is always a joy drive. U will be having a great experience.
    I will be selling mine after sometime due to some domestic reasons.
    PM for details
  16. #4515
    abid110's Avatar
    Jan 2014
    3,884
    90 Post(s)
    santros are not in good condition in open market...number plates missed, killed engines, out of color dashboards...il prefer a cleaner one in my budget. have long route to office so needed a small and manageable car
  17. #4516
    zahidbahi's Avatar
    Sep 2013
    104
    lucky in the sense that u dont had any major issues for last ten years.
  18. #4517
    aqibasit's Avatar
    Apr 2008
    3,178
    30 Post(s)
    2 Thread(s)
    Mine is without any single issue cuz bought it 0 meter. All original documents, file, plates intact.
    Sealed and sound engine which still throws water from tail pipe.
    Interior is super clean.
    PM for details
  19. #4518
    aqibasit's Avatar
    Apr 2008
    3,178
    30 Post(s)
    2 Thread(s)
    I have it since 2003, didnt faced any major issue...
    PM for details
  20. #4519
    abid110's Avatar
    Jan 2014
    3,884
    90 Post(s)
    that is nice. tell me when you intend to sell - if it fall inside my budget.
    how much it give on cng full tank within khi?
  21. #4520
    aqibasit's Avatar
    Apr 2008
    3,178
    30 Post(s)
    2 Thread(s)
    I mostly drive on petrol, use only for office commuting. Gives around 14-15 kmpl with full AC.
    On cng it gives around 100km i guess with AC.
    PM for details
