Page 23 of 250 FirstFirst ... 1321222324253373123 ... LastLast
Results 441 to 460 of 4982
Like Tree536Likes
Thread: Hyundai Santro Fan Club
    u4usman4u's Avatar
    Apr 2006
    32
    4,873
    2 Post(s)
    Default Hyundai Santro Fan Club
    AOA. This part is purely dedicated to HYUNDAI SANTRO which is available in variants. Share ur experience here. Hyundai Santro Fan Club -502667
  2. #441
    Aqua's Avatar
    Jan 2006
    41
    384
    @jah
    i also have 2004 santro club, having same observation. i think check light is available only in later on models.
    be happy.
  3. #442
    Xplorer's Avatar
    Oct 2007
    41
    790
    10 Post(s)
    @ jah, Aqua
    I've Santro-02 model and it has Check Engine Light.
    It always light-up for about 3 sec when ignition key is at ON position, after that a click sound (from a relay) comes from under the gear console and then this light switches off.
    Its possible that your bulb has fused. Do check it!!!
    I think every EFI car has this light.
    @basim17
    Your mechanic is right. Install emulator so that there is no check engine light on CNG. To improve performance on petrol, reset your ECU by keeping -ve terminal of battery removed for about half an hour.
    To improve CNG milage, get the cng kit completely serviced, including cylinder service.
    Say NO to OPEN LETTERS
  4. #443
    Xplorer's Avatar
    Oct 2007
    41
    790
    10 Post(s)
    @basim17
    However emulator is nothing to do with CNG milage. It will just send a false signal to ECU that fuel injectors are working so that ECU does not give Check Engine warning.
    Installing emulator will never increase milage.
  5. #444
    usama1's Avatar
    Sep 2005
    37
    1,460
    @jah
    @aqau
    oooooooo sir jee kya ho gya hai...check lite is in all santros from 2000 onwards,means its present in santro plus, santro club and santro exec.
  6. #445
    jehanzeb_riaz's Avatar
    Mar 2006
    40
    478
    @Jah, @Aqua
    My Cousine had Santro Plus 2001 model. Check Engine feature was there so as we could see the light.
    I've got Santro Club 2003. I've never seen Check Engine Light since I bought my car (Brand New) but I know that Check Engine feature is there as you can easily observe it as Xplorer said. "It always light-up for about 3 sec when ignition key is at ON position, after that a click sound (from a relay) comes from under the gear console and then this light switches off."
    Once I've changed the Bulb of check engine light but no effect so I am not sure what the problem is, as I've converted my car to CNG as it is 2003 model before GV got introduced.
    Cheers.
    Life is too short to be pissed-off. We are Not Enemies but Friends.
  7. #446
    Xplorer's Avatar
    Oct 2007
    41
    790
    10 Post(s)
    @jehanzeb
    You mean in your car, Check Engine Light does not come for 3 sec when key is ON???
    You can do one experiment to check if this light and its wires are ok.
    Open the hood and you will see IAC motor fitted above throttle body(as shown).
    Hyundai Santro Fan Club -870318
    Remove its cable (after removing its wire-clip).
    Now start engine. Now Check Engine Light is must to appear, if there is no problem with light and its wires.
    Switch-off engine and re-attach the cable.
  8. #447
    Mar 2006
    40
    478
    hmmmmmmmm thanks Xplorer... I will check it. But I still think that there is some problem with wires or may be the 2nd bulb was also fused.
    Regards
  9. #448
    Xplorer's Avatar
    Oct 2007
    41
    790
    10 Post(s)
    Any one having service manual (workshop manual) of Santro?
  10. #449
    Xplorer's Avatar
    Oct 2007
    41
    790
    10 Post(s)
    Service manual (workshop manual) of Santro?
    Any one please???:^)
  11. #450
    rehanghani's Avatar
    Jan 2007
    Rawalpindi
    40
    29
    my santro 2004 club is having a problem that my reverse light is all the time on...........
    what to do with that ???
    any good idea from FAN CLUB Members.........
    looking forward for ur comments
    Thanx in advance
    Rehan
  12. #451
    Xplorer's Avatar
    Oct 2007
    41
    790
    10 Post(s)
    @ rehanghani
    Change gear oil, if you have not done it ever.
    Whats your odometer reading?
  13. #452
    ahmad2222's Avatar
    Sep 2008
    86
    7
    is there an automatic transmission version of santro
  14. #453
    clebx's Avatar
    Mar 2008
    Rawalpindi
    36
    19
    What power steering fluid is the best to use for Santro exec. What is the price of them as well
  15. #454
    rehanghani's Avatar
    Jan 2007
    Rawalpindi
    40
    29
    @ explorer
    The reading is 44k driven & yes i belive that gear oil is never changed.
    Changing the gear oil will solve the problem ?? or still i have to the dealer for that problem ??
    Thanx
  16. #455
    Xplorer's Avatar
    Oct 2007
    41
    790
    10 Post(s)
    @rehanghani
    Changing gear oil will hopefully solve your problem.
  17. #456
    clebx's Avatar
    Mar 2008
    Rawalpindi
    36
    19
    Xplorer
    I reset the ecu but the problem still occurs on petrol ( lots of jerking of the car )
  18. #457
    iamadee's Avatar
    Mar 2008
    41
    1,827
    22 Post(s)
    Hi Guys,
    Can someone tell me where to get power steering for my santro. I guess a member told about some guy in BilalGunj. Is there any contact of the guy available, if yes please share i want to get my club powered its really difficult to handle it.
    Sharing is caring....
  19. #458
    iamadee's Avatar
    Mar 2008
    41
    1,827
    22 Post(s)
    Hi Guys,
    Helloo
    anybody here........
  20. #459
    Mar 2006
    40
    478
    @Xplorer
    Went to Sajjad Motors Jaild Road last Saturday for my Santro's maintenance.
    As it has done 108,000 Kim’s so I changed Timing Belt, Timing Bearing, Fan Belt, A/C Belt, Front Break pads, Break Service, Engine Oil, Oil Filter, Air Filter and Tuning and It cost 10K Rupees
    Good thing is its like brand new again
    Anyways I asked them to check the "Check Engine" light and feature as I never seen this light in my car from day 1. They've confirmed that in this model (2003 Nov) this feature is not present.
    The End...
  21. #460
    rauf24's Avatar
    Oct 2008
    42
    Friends,
    I wish to buy a Santro 2002. Its petrol; immaculate condition and demand is 315,000/-. Kindly advise me is it good price?
