Page 62 of 250 FirstFirst ... 1252606162636472112162 ... LastLast
Results 1,221 to 1,240 of 4987
Like Tree536Likes
Thread: Hyundai Santro Fan Club
    u4usman4u's Avatar
    Apr 2006
    33
    4,873
    2 Post(s)
    Default Hyundai Santro Fan Club
    AOA. This part is purely dedicated to HYUNDAI SANTRO which is available in variants. Share ur experience here. Hyundai Santro Fan Club -502667
  2. #1221
    Nasir_usman's Avatar
    Aug 2010
    27
    42
    please tell me the configuration of spark plug wires? means which wire goes to witch cylinder. i have messed with mine, and i don't want mechanic either to do the same. they will connect wires as looks like. but i want to know how to connect them.
    4 Coils
    cylinders 1 2 3 4
  3. #1222
    Aug 2010
    27
    42
    Quote Originally Posted by Rizwan5 View Post
    Hi everyone!
    I want some expert suggestion about engine oil, I am using zic A+ since buy of my santro prime. Laterally i visited my mechanic who told me that he has no question on Zic A+ quality but as lahore heat is about to start and oil is thinner it cannot give that performance so its better that you should re-change oil earlier than normal may be after 1500-2000 KM. Now i am confused should i go with my mechanic or go with Zic A+ normally?
    go with zic A+ normally.
  4. #1223
    Kamando's Avatar
    Dec 2009
    127
    7 Post(s)
    Quote Originally Posted by Xplorer View Post
    If no thermostat valve is installed, then the procedure is very simple. Just remove radiator's upper pipe and insert lawn pipe into it. Keep water flowing till clean water starts coming out of the radiator.
    never do it guys
    u r going to damage engine head block ..........
    ( sudden cooling will contract and deshape water lines and adjacent area , one of reason cars have thermostat valves )
    always use preheated water ....never use lawn pipe or tap cold water
    regarding caltex coolant never use it pure mix it (40% water 60% coolant or vice versa )
    if u r putting caltex coollant first time unless zero meter car , rust wil accumulate after 3 to 7 days( depending upon car use ) and radiator might jam ( due to anti rust function )hosing joints might also leak so keep eye on housings .......
    have to re wash and replace the coolant lets say about 700 to 1000km ...
    u might have to re do procedure if too much rust in radiator..............
    then you can enjoy caltex coolant ......
    its very nice and if u have used it in zero meter car no rust will come in radiator even after 1lac km
  5. #1224
    Morani's Avatar
    Nov 2008
    33
    348
    2 Post(s)
    No one having any trouble with their santro or everyone is having a worldcup fever?? ...
  6. #1225
    Horse_rider's Avatar
    Sep 2009
    30
    1,364
    3 Post(s)
    Quote Originally Posted by Morani View Post
    having cricket fever.
    현대 애인
  7. #1226
    iamadee's Avatar
    Mar 2008
    41
    1,827
    22 Post(s)
    Quote Originally Posted by Horse_rider View Post
    must have cured by now....
  8. #1227
    Subzwari's Avatar
    Mar 2009
    36
    415
    fellows, i need to replace battery of my santro. What are your recommendations on this....phoenix is getting popular these days....how about AGS and Volta...post your comments...thanks.
  9. #1228
    iamadee's Avatar
    Mar 2008
    41
    1,827
    22 Post(s)
    AGS is good, as per my experience. If budget is not a issue i'll recommend opting for ACDelco dry battery for better look and life of your engine compartment.
  10. #1229
    Sep 2009
    30
    1,364
    3 Post(s)
    Quote Originally Posted by iamadee View Post
    Lolll, yes you are right
    현대 애인
  11. #1230
    Faisal.Tasleem's Avatar
    May 2010
    Multan
    24
    36
    Its a 2 wheel dirve right??
  12. #1231
    Morani's Avatar
    Nov 2008
    33
    348
    2 Post(s)
    sure it is...
  13. #1232
    Waverunner's Avatar
    Dec 2010
    11
    Hey guys, thanks for the earlier help. My santro is giving a new problem. The AC keeps tripping when the car is in idle mode and it starts when the car starts moving. I tried getting the rpm raised, that worked for a while but it has started again. What could be the problem ? The car shudders in idle mode. Any help with pictures would be helpful. Don't wanna get ripped by an auto mechanic lol
  14. #1233
    iamadee's Avatar
    Mar 2008
    41
    1,827
    22 Post(s)
    Quote Originally Posted by Waverunner View Post
    Try checking the air filter (if its choked or healthy) and make sure the jack in the place highlighted is properly pressed, try cleaning and then set the RPMs from throttle body.
    Also does the problem exists only on CNG or Petrol only.
    Hyundai Santro Fan Club -224917
  15. #1234
    Sep 2009
    30
    1,364
    3 Post(s)
    (don't know whether there is temperature control knob exists in santro or not if yes then)
    If you recently bought your santro. Then may be the prev owner has changed the AC thermostate settings for frequently tripping which cause less fuel consumption.
    현대 애인
  16. #1235
    Waverunner's Avatar
    Dec 2010
    11
    Appreciate the swift response bro. I'm gonna try it out today and let you know. The car also jerks slightly in second gear. Could that be related to the air filter as well ?
  17. #1236
    Sep 2009
    30
    1,364
    3 Post(s)
    1st tune your car which includes filter cleaning and rpm settings etc. Then go for the AC thingy.
    현대 애인
  18. #1237
    romano's Avatar
    Feb 2007
    46
    1,520
    16 Post(s)
    Default battery
    attn Subzwari: I put in a Volta maintenance free battery in my car. Its working fine so far.
    http://groups.google.com.pk/group/vwcop
  19. #1238
    romano's Avatar
    Feb 2007
    46
    1,520
    16 Post(s)
    Did I mention I put Pirelli 155 tyres on the car last month? Great move, car rides a few mm higher (no more speed breaker worries) and the grip and road noise issues both improved!
    Did a quick run up and down to Lahore, perfect ride! The previous owner had put 165/65 Japanese tyres, and they were not up to mark. Low ground clearance, and car tended to skate/slide under heavy braking.
  20. #1239
    umairayyaz's Avatar
    Dec 2010
    23
    Dear ,
    I went to hyudai town ship today as my car santro 2004 club , is having oil consumption , they checked and recommended rings change, they gave me the estimate of 20 -21 k , can any one recommend me any other good mechanic in lahore who can change rings of santro , i want an estimate as well , please guide and reply
  21. #1240
    iamadee's Avatar
    Mar 2008
    41
    1,827
    22 Post(s)
    pm replied
