Page 94 of 250 FirstFirst ... 44849293949596104144194 ... LastLast
Results 1,861 to 1,880 of 4982
Like Tree536Likes
Thread: Hyundai Santro Fan Club
    u4usman4u's Avatar
    Apr 2006
    32
    4,873
    2 Post(s)
    Default Hyundai Santro Fan Club
    AOA. This part is purely dedicated to HYUNDAI SANTRO which is available in variants. Share ur experience here. Hyundai Santro Fan Club -502667
  2. #1861
    rizkhan2010's Avatar
    Oct 2011
    37
    1,858
    20 Post(s)
    7 Thread(s)
    which oil filter do u guys use??? and when do u change them?
  3. #1862
    RehanBhatti's Avatar
    Apr 2012
    53
    Today,subframe has been shifted forward from left side and 95% caster is fine now.
    car is not pulling left anymore.
  4. #1863
    iamadee's Avatar
    Mar 2008
    41
    1,827
    22 Post(s)
    Quote Originally Posted by rizkhan2010 View Post
    At every oil change or 4k which ever comes first. I am using guard these days, previously i was using fuji both are fine.
    Sharing is caring....
  5. #1864
    Oct 2011
    37
    1,858
    20 Post(s)
    7 Thread(s)
    Quote Originally Posted by immad100 View Post
    throw inn ngk bkr6egp platinums,forget emm changing atleast for about 50k yes yes 50,000 km a set of four costs 1300rs these days 1500maybe.
    get ultima low resistnce plug wires and forget caring about that.
    oil....ammmmmmi use havoline,drive it for 1.8k km,then change it agAIn,same as for oil filter.
    @immad100...u change ur car's oil every 1.8k km?? ( 1800km) isnt it early?? tell me the exact nomenclature of the oil u use dear and the filter too..
    and @iamadee...which oil do u use...detailed name and grade etc
  6. #1865
    iamadee's Avatar
    Mar 2008
    41
    1,827
    22 Post(s)
    i am using ZIC Z+
  7. #1866
    immad100's Avatar
    Aug 2010
    5,503
    26 Post(s)
    8 Thread(s)
    i prefer to change it as early as possible because my car is not like a stock g4hc motor,engine bears quite alot of load,it is the fastest 1.0L around so i have to take care of the motor specially,i change the oil max at 2.0k not even a singly kilometer more than that.i use havoline,i'l tell you the exact specs once i go through the oil can which i threw in the trunk
    ''Peace is an unstable equilibrium,that can only be preserved by acknowledged supremacy and...equal power.'' ''We give up the fort when there is not a man left to defend it.''
  8. #1867
    immad100's Avatar
    Aug 2010
    5,503
    26 Post(s)
    8 Thread(s)
    Quote Originally Posted by iamadee View Post
    i am using ZIC Z+
    zic caused bad valve seals to my motor,had to re-do the head.
    that was the day i left using zic.poor lubricant.
  9. #1868
    Apr 2012
    53
    Havoline in the best engine oil so far.
  10. #1869
    attabros's Avatar
    Feb 2012
    37
    Default RPM on CNG
    I m facing a problem in my SANTRO on CNG , when i release the accelerator the RPM comes down the car vibrates for 1 to 2 seconds & then RPM stables automatically.
    When i convert it in petrol there is no such issue.
    What might be the problem.
  11. #1870
    iamadee's Avatar
    Mar 2008
    41
    1,827
    22 Post(s)
    get the car tuned from 3s and u will be good to go. its probably some sensor which needs cleaning.
  12. #1871
    Oct 2011
    37
    1,858
    20 Post(s)
    7 Thread(s)
    what about the rest of you guys..which engine/mobil oil are you people using (if possible share complete specifications)...
    i am using Shell Helix HX5 10w-40...!!! (in simple terms yellow packing wala )
    and i change oil after 3000km...!!!
  13. #1872
    Horse_rider's Avatar
    Sep 2009
    30
    1,363
    3 Post(s)
    There is a minor leak of coolant from the upper pipe (attached to the engine end), the leak is not from the pipe rather it is from the circular shape thingy (don't know what is this, might be a thermostat).
    But i remember it was once broken by a mechanic when he was installing thermostat back. and he has done some JUGARR type of work, I asked him whether I should take a new that THING or not, but he told me that it will be okay for a while. now that Mechanic is not available, I have to check with some other mechanic, but first I want to get help what was that THING? (Just a cover?)
    post the pic.
    could be the hose pipe attaching end.
    Hyundai Santro Fan Club -398434
    Hyundai Santro Fan Club -398435
    현대 애인
  14. #1873
    iamadee's Avatar
    Mar 2008
    41
    1,827
    22 Post(s)
    I was using Havoline for last couple of years, its been this last two time that i have shifted to ZIC A+, and by far I am very satisfied with the results.
  15. #1874
    Sep 2009
    30
    1,363
    3 Post(s)
    Millage matters, when it comes to choosing the synthetic, semi-synthetic or mineral based oil.
    현대 애인
  16. #1875
    Apr 2012
    53
    Quote Originally Posted by Horse_rider View Post
    so,which oil gives good mileage in santro?
  17. #1876
    Sep 2009
    30
    1,363
    3 Post(s)
    Quote Originally Posted by RehanBhatti View Post
    my bad, I mean to say, Total KMs driven, i.e less driven cars need fully synthetic, mid ranged need semi-synthetic and old need mineral oils.
    현대 애인
  18. #1877
    aqibasit's Avatar
    Apr 2008
    3,178
    30 Post(s)
    2 Thread(s)
    Hyundai Santro Fan Club - 398434
    Hyundai Santro Fan Club - 398435
    Just Apply magic deposi on the leak
    Body kits available for all cars...
    PM for details
  19. #1878
    iamadee's Avatar
    Mar 2008
    41
    1,827
    22 Post(s)
    Quote Originally Posted by aqibasit View Post
    The magic will not last long. I'd recommend changing the water jacket as it will not be much expensive, and in case of any worst case scenario you will end up in a heated motor.
    You could try from old parts market as well, if new is not available.
  20. #1879
    Sep 2009
    30
    1,363
    3 Post(s)
    ^^ Thanks to everyone, Now I have another problem, last night a dog was badly hit on Mardan-Malakand road while going to Malakand, I could not apply breaks suddenly, Number plate and lower bumper cracked, the AC condenser fins are also slightly bent, the fins will only be required to straighten by the AC mechanic (Minor damage). while the bumper is cracked exactly in lower middle area below the JALI. pictures will be uploaded soon.
    Hyundai Santro Fan Club -399795
    Now I need new bumber, from old parts market, new from 3S dealer or from local new parts market, need your suggestions, and also please share its price. my car is black.
    Or I should repair and paint the bumper.
    Thanking in anticipation.
    현대 애인
  21. #1880
    aqibasit's Avatar
    Apr 2008
    3,178
    30 Post(s)
    2 Thread(s)
    Hyundai Santro Fan Club - 399795
    just repair the bumper and get it repainted
    PM for details
