Results 1 to 5 of 5
Thread: Removing dashboard of Santro... pls guide
    Xplorer's Avatar
    Oct 2007
    41
    790
    10 Post(s)
    Default Removing dashboard of Santro... pls guide
    Any one having experienced this pls. give me some guideline to remove the dash of Santro.
    It'll be a great help for my diy project.
    (The reason to remove dashboard is to change/repair the leaking heater core.)
    Say NO to OPEN LETTERS
    Desibaba2's Avatar
    Jul 2007
    30
    447
    Cassete Player ke upper teen plastic ke (button type) pieces lagey hein, unn mein sey right orr left waley ko screw driver se carefully nikalo, jab nikal jaein ge toh dono mein aik screw laga hoga, screws ko khool lo, orr aik screw ash tray nikalo gey toh wahan bhi hoga, ussey bhi kholna hoga, orr phir panel ke sides mein screw driver laga ker carefully khool loo... i hope you get it...
    Driving is not a fun - its a responsibility
    jehanzeb_riaz's Avatar
    Mar 2006
    40
    478
    @Xplorer
    Your DIY project would be very helpful for me, as I've the same issue pending to sort out.
    https://www.pakwheels.com/forumreply_az_TopicID!62159~ForumID!10~pw.html
    Regards,
    Life is too short to be pissed-off. We are Not Enemies but Friends.
    Xplorer's Avatar
    Oct 2007
    41
    790
    10 Post(s)
    @Desibaba2
    Thanks a lot dude!
    You mean first we have to remove the panel and then the dashboard will come out?
    Pls. give some more details.
    hameeds01's Avatar
    Jul 2005
    892
    19 Post(s)
    Removing dashboard of Santro pls guide -805531
    Removing dashboard of Santro pls guide -805532
    Removing dashboard of Santro pls guide -805533
    Removing dashboard of Santro pls guide -805534
