Results 1 to 3 of 3
Thread: Santro Problem
    faisal2193's Avatar
    Dec 2006
    38
    118
    Default Santro Problem
    Dear All,,
    I saw my passenger side carpet wet three days before. I thought it might be due to washing. but i checked it time and again and carpet is still wet. Plz advice me what could be the reason.
    whiteangel's Avatar
    Nov 2005
    2,240
    9
    65 Post(s)
    Might be air conditioner water dripping inside. Check the evaporator drain plug, to make sure it is not loose or clogged
    Never argue with an idiot, they drag you down to their level and beat you with experience.
    deadalive123's Avatar
    Dec 2005
    Faisalabad
    31
    2,322
    Same happened with me in winter when i started using Heater.
    mechanic told me there is a heater related bowl which's quality isn't good and hardly work for 2 years and then start leaking,
    go to ac mechanic, ask him to check if its related to heater, if yes then ask him to close heater valve instead of spending 4k on its repair...
    DeAd-AliVe --- A dIfFeReNt 1
