Results 1 to 4 of 4
Thread: Santro problem--urgent
    israr_x's Avatar
    Feb 2007
    Rawalpindi
    32
    57
    Default Santro problem--urgent
    i just hve changed the CLUTCH PLATE of my Santro.. but uss say GEAR tight hu gaya ha santro ka..
    Wesey Rukki gaari ka gear nahi hota ha.. lekin jab start karo tu PEHLA aur DOSRA gear Bohat SAKHT hu gaya ha Mushkil say lagta ha....
    tu asal chakar kia ha??? Clutch plate NEW honay ki waja sy tu nhi??
    GamezBond's Avatar
    Oct 2007
    London
    43
    603
    Did you take it back to the mechanic who changed the cluch?
    If you changed the cluch yourself, I guess you might need to tighten the clutch too so that it can press further when you press. (if it is cable driven?)
    "Inna mal a'maalu binniya"
    "Actions are based upon intentions"
    Xplorer's Avatar
    Oct 2007
    41
    790
    10 Post(s)
    GamezBond is right, problem could be with the tightness of the cable.
    It is also possible that during repair work mechanic took out gear oil and then he refilled it but some of it was lost during this process and now gear oil is not up to the mark.
    Say NO to OPEN LETTERS
    Thunderbolt's Avatar
    Jan 2006
    90
    Replaced Complete set i.e. Pressure Plate, Clutch Plate and bearing or simply CP. Secondly CP you replaced is genuine or compatible and lastly which grade oil was used. If it is cable was the condition of cable good, oiled. Check it.
