Results 1 to 4 of 4
Thread: Santro Exec gear problem
    mesmerizer's Avatar
    Jul 2007
    27
    129
    Default Santro Exec gear problem
    Hello everyone.. I have a Santro Exec 2008.. Lately i have been experiencing issues with the gear shift (FIRST GEAR)..
    It is very unsmooth and most of the times it doesnt work at the first time and i have to try two three times and sometimes go back to neutral leave the cluth and then apply it again..
    other gears are working fine..
    Any suggestions on what could be the problem? And how it can be rectified..
    God gives and forgives, man gets and forgets.
    ahsanzs's Avatar
    May 2007
    560
    8 Post(s)
    You are actually forced to 'double clutching'.
    The clutch doesn't disengage properly due to:
    1. Shortening of wire due to change in climate (winters).
    2. Elongation due to steel relaxation.
    3. Wear on the clutch plate itself.
    It can be adjusted within 2 minutes by a practiced mechanic. If you don't get it adjusted the other gears will also start creating shifting problems in around 4-5000km.
    The low down on CNG cylinder testing: https://www.pakwheels.com/forums/cng-lpg/170776-done-cng-cylinder-testing-hdip-photos
    aantherax's Avatar
    May 2006
    33
    3,032
    4 Post(s)
    Go to a mechenic and ask him to do clutch settings ...
    ~ Be a responsible citizen and always drive safely ~
    Saeed73's Avatar
    Jul 2008
    Other
    524
    Just Clutch setting needed for this,and don't try to leave Clutch in half and nor use Double-clutching Because it's new Santro Exec, otherwise Ur Plats will wear so early.
