Results 1 to 14 of 14
Thread: Grip problem with SANTRO
    athlon3ghz's Avatar
    Apr 2005
    34
    73
    Default Grip problem with SANTRO
    dear friends,
    I am very concerned with my new car. the tires seems to struggle with the grip on the road. Even when I am driving below 60 km/h and apply the brakes the car starts skidding and sliding. pls tell me if the problem is with the standard tires or the brake is too hard? I have absolutely no knowledge of tires or sizes so pls also give me alternate sizes and makes it would be better if its bridgestone since they are readily available in the market. thanks for any help
    regards
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    24 Thread(s)
    Get Alignment checked and change Stock General tyres.
    Keep a cool head and wear seatbelts!
    bluespark's Avatar
    Oct 2005
    Dublin
    34
    1,244
    change the stock General tyres...they behave as Ice rollers....give these generals and put something good like bridgestone,hankook....you probably need to spend some 4k along with the tyres....make a bargain
    Das Auto, Der Golf!
    shabazshah's Avatar
    Nov 2005
    45
    41
    Your Santro has GENERAL 155/70 R13 tyres as standard. They are very poor quality, available from AutoExpress for only Rs1200 per tyre.
    You need to go for a better brand, and a grippier size, whilst retaining the overall diameter within the accepted specs of the car.
    That Size wouldbe either 165/65 R13 (GoodYear is nice in this) or 165/70R13 (Bridgestone B700 is the best).
    Depending on what you go for the price will vary from between Rs1800 per tyre to upto Rs3000 per tyre (185/60r13 for e.g.)
    As soon as you change tyres get your wheel alignment checked - we have one of the most sophisticated 4 head laser machines in the country.
    After that you'll feel a MAJOR difference in grip.
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    24 Thread(s)
    shabazshah
    Which city r u from?
    sali2002's Avatar
    Feb 2005
    30
    1,077
    hello...
    try getting some good tyres of 175 max....in same diameter....but 1st be check the alignment.........
    Thanxxx
    R.I.P. Follow
    aridsoul's Avatar
    Aug 2003
    39
    8,496
    Change the original tyres...........
    levin's Avatar
    Oct 2005
    Select City
    51
    23,112
    5
    95 Post(s)
    6 Thread(s)
    agree with all....use low profile tyre, i had santro a few yrs back. i found it has very soft suspension. reminded me of renault 4
    ,,, unless you know the track, you're not good enough to sit behind the wheel." K T
    shabazshah's Avatar
    Nov 2005
    45
    41
    Quote Originally Posted by spectra
    shabazshah Which city r u from?
    FROM LAHORE
    RetardedBuddy's Avatar
    Sep 2008
    Select City
    7
    13,785
    2 Post(s)
    Welcome back after 4 years
    Bilaltq's Avatar
    Mar 2004
    Select City
    26
    10,311
    10 Post(s)
    wow 4 years later! It's always good to see some good old threads revived.
    This comment was made by a person with a tested IQ of negative 9.
  12. #12
    aantherax's Avatar
    May 2006
    33
    3,032
    4 Post(s)
    that was the world's most quickest response i guess
    ~ Be a responsible citizen and always drive safely ~
  13. #13
    shabazshah's Avatar
    Nov 2005
    45
    41
    Hi CHAPS
    Was trying to be fashionably late....
    But mistimed it! :-)
  14. #14
    Site Banned Follow
    Zeejigs's Avatar
    Aug 2006
    Rawalpindi
    30
    3,121
    wow!!! answered back in no time!!!LMAO
