Results 1 to 3 of 3
Thread: Check Light On Santro GV
    abidhameed's Avatar
    Nov 2005
    39
    14
    Default Check Light On Santro GV
    AOA
    i have santor GV.
    i am having problem with my car in morning when i start my car, check ligt gets on and car speed enhance.
    after 2 or 3 inutes check light gets off and car speed also get normal.
    problem is faced in winter only.
    any suggessions.
    regards
    abid
    chinyoti's Avatar
    Sep 2005
    27
    11,956
    5
    107 Post(s)
    5 Thread(s)
    have the same problem in my baleno since the advancer was changed, but didnt hapend in the morning particularly. happenes wen the car is idle and im pressing the brake as hard as i can. havent got it checked but it happen that the check light appears and the RPM goes to around 2000-2500
    after a few seconds its normal and the chk light goes
    Get over the fact that Xli lacks power windows, Its an Xli because it lacks thoose features or else it would be a Gli or an Altis if had all the goodies.
    corruptgangster's Avatar
    Dec 2008
    34
    826
    well i hope the problem doesn't develops to a serius one for the two of u...
    get it checked since check engine light has issues to handle with ecu...and ecu is the most sensitive part of the vehicle so guys watch out.
    Regards,
