Results 1 to 13 of 13
Thread: SPECTRA PROBLEM
    rozi's Avatar
    Oct 2008
    Rawalpindi
    54
    6
    Default SPECTRA PROBLEM
    MY SPECTRA HAS FOLLWING PROBLEMS
    ^ ENGINE RPM GO DOWN TO 400 AND UP TO 1500 WHILE PRESSING THE BRAKE PADDLE
    $ SOME TIME ENGINE SHUT DOWN ON PRESSING BRACK PADDLE
    ! SEEM PROBLEM IN FUSE BOX
    PLZ HELP ME--- DOCTOR SPECTRA
    azkhan's Avatar
    Mar 2004
    28
    517
    20 Post(s)
    @rozi
    I think there is a problem with your IAC (idle air control) sensor which controls the idle rpm (rpm when accelerator is not pressed). Please tell also if check engine light is on? Hope this helps.
    Regards.
    Ali Zaib Khan Mohmand.
    //.....Don't bully Korean cars.......//
    fizz's Avatar
    Apr 2007
    26
    552
    this happens when the car is at its place or moving?
    -go with the beat, rock the street
    syzuhair's Avatar
    Mar 2009
    77
    222
    @rozi. Remove the brakes from ur car.masla katm
    People need not be told what and how to do,
    They need to do it themselves to know if they are doing it right or not !
    ibadaslam872's Avatar
    Feb 2009
    19
    6,107
    5
    49 Post(s)
    @syuuzhair bhai
    lolz
    Under the Coconut tree
    syzuhair's Avatar
    Mar 2009
    77
    222
    @lianarules sahi bat ha yar brakes ke wja sa Rpm khrab ni hona chaiya
    rozi's Avatar
    Oct 2008
    Rawalpindi
    54
    6
    AOA--THANX FRIENDS--I FOUND THE FAULT-- I JUST REMOVE THE TAIL LIGHTS FUSES AND THE PROBLEM FINISHED---PROBLEMS WAS SHORT CIRCUITS OF FUSEBOX
    iLLDuDe786's Avatar
    Feb 2009
    New York City
    11,213
    you hav spectra problem .. you should contact "Spectra" .. lol
    syzuhair's Avatar
    Mar 2009
    77
    222
    @rozi. remove the fusebox also
    imrandahar's Avatar
    Jun 2005
    Sadiqabad
    34
    1,174
    2 Post(s)
    IAT sensor carb cleaner se saaf karo ur prob wil b solve
    ikd
    rozi's Avatar
    Oct 2008
    Rawalpindi
    54
    6
    Quote Originally Posted by azkhan
    @rozi I think there is a problem with your IAC (idle air control) sensor which controls the idle rpm (rpm when accelerator is not pressed). Please tell also if check engine light is on? Hope this helps. Regards. Ali Zaib Khan Mohmand.
    thanx--where IAC ( idle air contrl) sensor is installed in the engine?
  12. #12
    rozi's Avatar
    Oct 2008
    Rawalpindi
    54
    6
    Quote Originally Posted by fizz
    yes--happens in both cases--on move and also when placed
  13. #13
    GolMaal's Avatar
    Oct 2008
    28
    127
    Jaan de yaar kisay gaddi de gul kur
    Oye aay we koi gaddi aay
    Korea de khoti raihree
    Fred Quimby
