Hi All,
I have Honda City 2005 model newly purchased, the problem is when i drive my car at 60 Km or higher speed, its got floating from rear side which is very dangreous. Can anyone help me out to describe what can be a possible problem and also the solution.
Wheels agay peechay hue hain, get them adjust from mechanic and them alignment guy
dont DRINK AND DRIVE..(H)
^^aho
Wheels ki adjustment karwa li hai but same problem.
@rusty_racer94, I am a regular drinker, its not becoz of this.....
There could be 2 or 3 reasons behind that,Wheels alignment, balancing, air preasure, Tyre size (which could b differ with others) & gap/height between rear tyres & mud guard (only in cng case), which usually people get done coz of cng cylender.
apart with all the reason mentioned above.... it very much depends on which car did you have before this City..I have 2006 CiviC and after that i drove City... I felt the same as you are mentioning... but then i cameto know that ..City is very less road grip and stability as COMPARED TO MY PREVIOUS CAR (2006 CiviC)
waise... Air pressure in rear tyres and allignment will solve your issue to 90%
dear kindly check your car to a good alignment shop alongwith your mechanic and take the advice may be you need some 1.ALIGNMENT2.SOME BODYPART CHANGE3.DENTING FOR ACCIDENTAL PORTION SOMETHING
NO NEED TO WORRY EVERY SOLUTION IS POSSIBLE
