Engine oil lights blink..when car is idle...? but when i give some accelerator...lights stop blinking?? yesterday i change the engine oil but problem remain same?? what is the issue??
REGARDS
Bro definitely its a sign of weak OIL Pump.
is it create any problem/?? whats da price of oil pump??
car details please
Check the oil gauge it might me short cked change it will cost u 150 to 200 rupees if the light still doesn't go off then itd the oil pump.normally when the light goes off when accelerates then its the oil pump 90 out of 100 times.
has to be oil pump, get it checked on priority basis as it can damage your engine.
its honda integra....this problem occurs some time...not all the time....i m facing this problem from yesterday....
The major causes for this problem are,
1 - Defective oil pressure switch.
2 - Using of thin oil.
3 - clogged oil filter.
4 - Blockage in oil jackets.
5 - Dirty oil strainer.
6 - Loose main bearing.
7 - Defective oil pump.
Oil Guage Faulty. Needs cleaning or replace.
I second argtr65
He has come up with a good list and its in the correct order too. Troubleshoot accordingly, though you may swap the places on 6 and 7.
Good luck
problem solved ...nothig serious only the wire of light getting earth by touching through the body.... thnx anywayz
informative!
thnx....to check dis issue alwayz check that when v switch on the car....engine oil light comes up or not if its off and after starting the car its on... or blinking...then it was the issue of wire...other wise may b it was a issue of oil pump...some mecahincs told me that it was the issue of oil pump get it repaired as soon as possible otherwise engine get sizzed...bla bla bla ....but my cuzin set it in 1 min.
i am facing the same problem with engin oil light.https://www.pakwheels.com/forumreply_az_TopicID!108458~ForumID!10~pw.html
hope it is also the wire problem and not big that than...
