Well there must be something wrong with the belt :S
THIS MEANS THAT SOMETHING IS WRONG WITH UR ENGINE AND WILL BE WROST IN THE COMING DAYS SO PLZZ CHECK..!!
for God sake guyz its not the oil lyt. it shows that your air intake is working properly or not. lyt should be closed after the engine starts. if it doesnt chk the sensor and the intake system
is this car on CNG??????
it means bohut gari chala li ab uttar jao
@xalmanreyaz l0l..!
are there any EXPERTS on CHECK ENGINE lights here??
its check engine light..... according to mannuals.."report to ur nearest toyota/honda motors"according to local mechanic n local awareness gaddi chalti rehway jad tak rudi nainbut actually... its due to something abnormal stored in any sensor of u car...may be overcomes sometimes by removing ur battery terminals for some time and again connected.... but if its happening real time then it means there is some problem in any sensor of the car indicating any mechanical or electronic part of the car....~!I THINK U UNDERSTOOD ...in layman ... sequence... sorry for that~!
there is belth malfunctioning inside the engine which is called time belt that needs to be changed. 1000 ya 1500 ka karcha hy agher nahe change kia tu nia engine abi sy doond loo.
LMAO! Best thread in a long time!
No it is not the Turbo. You need to go to some good mechenic and ask him to hook it up to code reader to find the problem.
WRONG!
it simply means "check engine"
take it to a mechanic for diagnosis....
its a serious prblem btw...
In my car it even comes on if I don't properly close the fuel cap.The problem could be anything, just take it to a mechanic
LMAO @turbo
its check engine warning light maybe ur oil level is low or ur oil filter is blocked!!! its something u have to get ur engine checked!!
maybe ur airfilter sensor malfunctioning or any other problem is there under the hood this warning light is just showing u tht get ur car checked figure out the problem!!
