Salam to all,
I am having some problem in gear in my suzuki fx. it only happen when the car engine is cold at morning and evening when I am comming back from office:
1. 1st gear phans jata he although gari khari hoti he and its not moving. and 2nd gear laga k jab 1st gear lagao to lag jata he.
2. 3rd gear lagao to noise aati he jse something had a little friction.
Both of these problems get solved after 15 to 20 minutes drive and then again it appears only when car is parked for 6 to 7 hours.
Also when I start the car at morning, and if I drive it at high rpms in 1st and 2ng gear for some minutes, the problem is solved for that time.
It seems that the oil is the cause so i changes it to shell SAE-140 gear oil. but the problem is the same.
Experts, someone suggested me to use 75W-85 gear oil instead, so should I try it or there is some other thing wrong?
Mechanic says k gear box banwana parega and it is 6000 to 8000 Rs ka kharcha at all with Genuine parts and oil.
please help...
