This oil Contains Revitalizant
The compound is designed for protection of engine parts against wear and restoring repair of gasoline & diesel engines without disassembling. The gel forms a new cermet coating on friction surfaces (the parts grow in volume, restore their original geometry). As a result a renovated unit exceeds the performance level of a new one and will serve you 2-4 times longer.
Advantages
• restores and protects friction parts of the cylinder-piston group, crank and gas distributing mechanisms against wear
• reduces fuel consumption considerably (by up to 30% at idling);
• increases oil pressure to the nominal one;
• regains and increases compression in cylinders;
• increases engine power, improves acceleration capability;
• decreases noise and vibration level by 10 times;
• extends service life of the units by 2-3 times;
• protects the engine from negative consequences of cold start;
• improves engine operation in 50-100 km run;
• Maintains engine operation during 300 km in case of oil leakage.
Technical characteristics
General characteristics of the cermet layer:
Microhardness – 750 kg/mm2;
high corrosion resistance;
roughness Ra up to 0,06 mkm.
