What is the mielage of the car on odometer?
What made you service the pump and nozzles ate first place?
What is overall condition of engine, any blowback or sign of weak compression?
A retarded timing will result in what you are explaining here and if your engine is weak, you wont be able to acheive your desired results even by adjusting timing to perfect settings (which is not easy):))
