@ ser_gtr and rozzzzz
i appreciat you guys helping out realy i appreciat it you guys made my clubs flight into the known from unknown if you know wht i mean
guys who dont know abt 4age 20 value
there were 2 20 valve a ST(silver top) a BT(black top)
4A-GE (20-valve)
Silver Top 20-Valve 4A-GE
Fourth Generation "Silver Top"
The fourth-generation 4A-GE engine was produced from 1991 to 1995. It has silver cam covers with chrome lettering, hence the nick-name "silver top This engine produces 158 hp (118 kW) at 7400 rpm with 162 N·m (119 ft·lbf) at 5200 rpm of torque compression ratio (10.5:1) and yes it also had the vvt The Toyota Variable Valve Timing
Fifth Generation "Black Top"
The fifth-generation 4A-GE engine produced from 1995 to 1998 is the final version of the 4A-GE engine and has black cam covers thats y called the black top This revision increased the power to 165 PS (121 kW; 163 hp) at 7800 rpm with 162 N·m (119 ft·lbf) at 5200 rpm of torque compression ratio (11:1)
hmmmmmmmmm saw the toyota guys coming but the honda guys are now were to be seen
@n20ahsan
got an answere from levin and he said that
yes. if yr using fuel from pakistan, i d suggest your use fuel cleaner/octane booster bottlle to bring final ron of fuel to at least 93 ron. This stuff is avalaible on google search.
if yr living outside Pk you simply use at least 93-94 ron.
