aik ghanta k drive k baad gari ka self sahi kaam nhi karta i mean slow chalta hai kabhi kabhi to gari start b nhi hoti but jab thandi ho ya subha ko self maro to start hojati hai aur self sahi ghoomta hai but garam hony k baad masla karti hai plz dear tel me kia prob hai
I would suggest to
1 Have your battery properly check under load testing2 check your negative cables,use a dedicated negative cable from the battery to the starter motor mounting bolt.3 if your grounds are good, check that you are getting full battery volts at the starter motor trigger terminal when attempting to crank the engine.4 If the volts are low (common fault) use a starter relay in the circuit to supply full voltage to the trigger terminalcourtesy xulfiqar member @PW
i was facing the same problem in 00civic exi by following step 2.the problem was solved and the car is working perfect.regards
I have a 2007 alto, from last week i also encountering same kind of problem but in my problem my car's self got lil heavy i can feel it heavier than before but no issue with starting of the car.
Well as i know its bcoz of overheated engine i can also hear bubbling in my cars water bottle but usually it happens when weather is too hot and car is driven in low gears.
In addition to these get your car properly tune up and get throttle body service (EFi only) and get your self assembly serviced these are the most common probable causes of the problem you have mentioned.
well lot of suggestions but I think that as the starting ARMATURE in starter gets old it loses its efficiency when hot,go to a good electriecian
Agreed. Plus check your alternator (generator) if its giving full current.
if none of the above works than u may ask ur mechanic to adjust the distributor setting too... btw its most probably a sluff load fault. happened wid me whn i had a mehran
its indication to change ur battery
car is spectra its distributorless ignition system<TABLE id=post2213402 class=tborder border=0 cellSpacing=0 cellPadding=6 width="100%" align=center><TBODY><TR><TD style="BORDER-BOTTOM: #c7e2f0 1px solid; BORDER-LEFT: #c7e2f0 1px solid; BORDER-TOP: #c7e2f0 1px solid; FONT-WEIGHT: normal; BORDER-RIGHT: #c7e2f0 0px solid" class=thead> 23-05-2010, 08:05 PM </TD><TD style="BORDER-BOTTOM: #c7e2f0 1px solid; BORDER-LEFT: #c7e2f0 0px solid; BORDER-TOP: #c7e2f0 1px solid; FONT-WEIGHT: normal; BORDER-RIGHT: #c7e2f0 1px solid" class=thead align=right> #8 (permalink) </TD></TR><TR vAlign=top><TD style="BORDER-BOTTOM: #c7e2f0 0px solid; BORDER-LEFT: #c7e2f0 1px solid; BORDER-TOP: #c7e2f0 0px solid; BORDER-RIGHT: #c7e2f0 1px solid" class=alt2 width=130>manofpk </TD></TR></TBODY></TABLE>
problem solved dearelectrition serviced the startor motor cleaned it with petrol and made one new bush by kharad wala now starting is good even in hot day ,startor motor is rotating fast now
coool i was almost there...
Tune up ur Car.... Its only da problem of Battery or Tappet nothing else!
usually incorrect heatrange installation of sparkplug even causes this problem and secondly if knock sensor needs adjustment!
i have gotten exactly the same problem with my car 2-3 days before...i also thought that battery is weak but infact the self of car needed to be serviced..i went to mechanic to get the self serviced but he adviced me not to open self, according to him it will create problems in future...instead i got a kabli self of Mitsubishi from bilal gung (1600/- rs very good condition) and now my car is again half self start even its hot:)i think you u must replace the self.
Probably a bad crank sensor, get that checked to. recently relplaced my Balenos, it used to die when a bit hot, (by hot i mean normal temprature but some running)
It didnt used to start but started after 15mins
Had the same problem..follow step 2!!
