today when i insert the car key and tried to start. i find myself in a strange problem.... the key was not turninng to igniton and when i tried to pull and re insert...it was not coming out!!after alot of struggle i call in the key maker and he sort out the problembut i want to know why it happens?
maybe your key is bent
car?
i think u have honda civic above 2003/4 model am i right ?
Why u did'nt asked the key maker about the problem.?
its 2006 exi....i asked he said k aaj kal is model mein yeh problem arai ha....and he changes some bushes....
Key was genuine or cloned one?
I also faced the same problem in my civic 04/05. but key was cloned one.
it was genuine bro
awww....not kwl
the problem with newer Honda keys - their teeth get rounded and then stick in the ignition barrel - the smithy then just yanks the teeth levers in the barrel - and the customer is happy - JUST ONE POINT, anyone can spin that ignition with a dumb key
well i also faced that problem once in my civic 2004 but didnt know that every second owner of civic is facing the same......suppose if the teeth of the key got round then it should create problem in the door lock too.....i have faced that problem in ignition point n after a hard struggle i successfully brought that out with out any key maker help and after that uptill now its going fine...dont know why it happened....
there is some plate ( patri ) jo k kabhi kabhi mur yani mold ho jati hai jis ki wajah se key nain ghomti aur honda ki chabi computerised hoti hai agar zor se yar jaldi se lagai jae to bhi yeh problem ho jata h.aur iska hal yeh h k steering cover khol kr key wali assembly nikal kr us patri ya sheet ko sedha kr k reati k sath ragar keer phir usko fit ker denay se thek kaam kerti hai key
and to avoid this problem dont try any other key even of same model it will creat more problem later
