There are three types of Toyota viscous fan clutch oil. All are silicone based and rated at 3000 cST, 6000 cST, and 10,000 cST.
The part numbers are 08816-03001, 08816-06001, and 08816-10001, respectively for an 18 mL bottle shaped like in the picture with a twist off single use application. Each bottle is 18mL, and 2-3 may be needed.
The 3,000 cST was for all Toyotas except for the Celica which uses the 6,000 cST. The 10,000 cST is used only for the big Toyota SUVs.
