You can safely use these upto 5000 KM. Both are latest standard oils and work very well. I will recomend Petromin Ultra 7 amazing oil and it helps in oil burning.
btw I also had oil leakage problem from seals and Liqui moly oil savour really helps in stoping this, You can look up online about it.
But using 20w-50 will also help in reducing this leakage.
yar leave every thing.daily subha car ko use karnay se pehlay 15min start kar k idle rehnay do.daily aisa karo *** tu kabhi oil kam nai hoga.
You need a rings job bro. Get it done from any genuine Honda dealership. Will cost you a bunch but you'll get the job done without any problem.
so again fill it............
Try petromin ultra 7 which is 20W50 and is very good oil i m also using it in my car.
Yup bro i ll gonna use Petromin ultra 7 this tym and before that will also go for fixation of leaks to avoid any further hazards
Thanks & Regards,
Bro rings piston job is the last resort and as far as i guess its not a engine issue
Bro I will InshALLAH ....
Is this a myth, cant find a logic in it regarding decreasing issue
If not leakage then its rings problem....
You can avoid it by using thick oil or stapy in your normal oil (dont know exact name and spelling).
To resolve it permanently, you have to do ring piece work. Will cost you around 7k.
if you are facing ring piston problem then probably your car will be giving blue smoke too... whatever you can add a STP bottle for increasing the viscocity of oil and your engine will not decrease oil
Wrong
"No matter how cold it is. Just keep idle for less than a minute and drive away. Engine will gain its optimum temperature itself by adjusting built-in mechanism"
Quoted from Honda's Users Manual
Bro wots that stapy can u elaborate it??
Its STP (not Stapy) oil treatment. its a can of thick, viscous additive for engine oil. one 440ml pack (approx) is enough for 3 - 4L oil. if the your engine capacity is 3.5 litres then use 3.1L engine oil and then add STP. NEVER over FILL.
Note: Oil treatment is just a temporary treatment. Not advisable for long term.
ok thanx bro for elaborating
Ones I had used Zic oil in my mini pajero, and after 20 days the oil was 50% decreased... zic oil is suitable for new cars and not for old cars....
Thanks bro.....STP also help in cleaning the engine.
