@poster
Sir ji It's better to remove your cng kit. And do the mods told by wasay this thing will help you to some extent. Plus if you require then go for instant power which is nitrous simple and easy solution. For nitrous do get some suggestions then go other wise you will end up with one or the other thing.
@Wasay
Vafc will be able to handle it with out glowing CEL and errors ?
