Hi Experts, i am running Santro Club 2004 (CNG installed). Few days back unfortunatley on motorway my car engine got heated (due to lose rediator cup). Mechanic checked it and found out that only gaskit needs to be replaced which i did. But after that when car engine is start at halt engine sounds normal even when you press the accelarator everything seems ok, but once you start moving the car even in all gears and in any speed some tik tik sound comes out of engine which is kinda annoying. Mechanic checked it again and said tappets needs to be adjusted which he did but problem is still there. What may be the reason?
Good Day, Jibran Khizar
had this tik tik sound in my car and got the tappets adjusted once,the sound dint go,then went to honda pit shop and got them adjusted again,and the noise disappeared..the tic tic is typical tappets voice
There's a stone or a nail stuck in your tire.
+1. if the tic tic is from engine , it is 100% sound of tappets..
If the tik tik is due to tappet, it should arise in idle aswell.
It may be due to weak engine foundation,any loose or worn parts of suspension system,excessive play in cv joints,worn or loose brake pads/caliper assembly,and any other loose component of engine or transmission etc,etc.Get it checked thoroughly.
may be some one put time bomb in the engine so it is ticking:P
may be knocking bicoz of wrong or advance timing
+1
