guys help me what is strut bar
its a bar which gets fit onto each side of engine bay and it helps in handling and cornering at high speeds.
It helps ur chasis to be intact and car doesn't sway at high speed.
it also tightens your suspension as in sports cars and increases stability although you gotta compromise lil bit on comfort!
so is it usefull for me to install in my 2004 civic or not?
depends if you wanna compromise on your comfort and go sports!but not dat of a good idea if its a family car n where in pk are you gonna maneuver through sharp turns and race, think?i recommend to stick with comfort due to khadda roads of pk!.....
hmm u right bro
any use of it in my alto :S ??because when i even change lanes at high speed aesa lagta hay k gari mai body-roll bohot zyada haywill a strut bar help in stabilizing that ??
There is no use of installing it in stock family cars unless ur car is modified in real means.
ok thanks
