Assalam O Alaikum Guys,I m having a problem of Very Dim Meter Lights while Pressing Brake or Giving Indicator when i give Indicator Meter and Cabin Light(If On)starting Dim.. Battery and Alternator has changed Last month... U know Guys whats this??
batrry changed?? still this prob... ur generator might not be working resulting in low battry..do u get SULF fine??
Yea starting is fine too and alternator is wrking properly otherwise Battery lights blink
bad ground to body.
check voltage drop at engine and battery then car body and battery
I think xulfiqar is right, check if the ground wire is properly connected to the body, if not then connect a strong wire from negative terminal to the main body using a bolt or something.
