AoAmy mehrans engine oil level is reducing i hav checked for leakage problems but there was no leakage. plzz help me, wat is the reason for oil reducing and wat shall i do.
how much it is driven?
Its seems to me that your piston rings are weak. You may required to replace its piston rings, valves, valve seals, gasket etc or might be a complete engine overhaul (new piston and bore). Consult with a good and honest mechanic asap.
n wat will be the cost of complete overhual
the cost depends on the engine condition. if only rings are replaced then it will be about 8k. the exact cost can only be provided when it is opened and inspected
89000
there is no other cause of engine oil reducing except piston rings,valves, valve seals, gasket etc are weak??
these are most probable.
