I take a compression tester with me - but the sellers I dealt with know me and let me rummage through all their engines. The first check point is the valve cover/oil cap, remove starter and see if its clean inside the bellhousing and lastly check compression - if you dont have a tester - take a spanner to the crank - it should bump on every compression hump
