hi to alll here
i am having an issue mine headlight suddenly not glowing so much and they are glowing as i increase the race and dim when i am not on race..
please help me in this.
This is normal. Install relays to fix it. If u feel it wasnt so bad before then check the alternator and battery
ok thanks for that relay for headlights i should put on ....
same issue with my 2011 cultus it's normal bro, nothing to worry about!!
No harm leaving it as it is. But relay will increase brightness by 20 percent and keep it stable so that this wont happen.
ok coool thanks ..... one more things is no any issue created if i used 100 volt tube in headlights ..or there are any tubes come sin white shade .... not the hid one ..but same like we use yellow tube any tube come in white shades....
well u can put 100 watt bulbs easily but in that case u need to install relays otherwise wiring will get damaged as the 100 watt bulb puts twice as much load as the stock bulb.
ok bro thanks for the info and help ..
