1800 cc will it work have any advice
I have a 2003 Toyota Allion which is twin sister of Premio, have been running it on CNG without any problems for 6 months or so, the only thing you need to care about is to run it on patrol from time to time else the fuel pump gets screwed.
if fuel pump is electronic it will not work if its on cng so no worries.
but hw will i knw its electronic i had cng in corolla x and it works fine in that its 2005 model
Cng is not economical on premio 1800cc engine in city but on highway its better.if you afford a second car so my advice is to buy a suzuki mehran, alto , cultus . . premio not suit CNG its a luxuary car
it s not abt ecnomical my question is will it work or not have any one installed it and my drive is mostly of high way kind motorway not in city for city i have alto
Why it will not work on CNG? this is some thing you need to get done and most CNG wala's dont do it.
Electrition will install a relay that will cut off power supply to Pump when you convert your car to CNG.
off course it is like that , u went in detail ! by the way if someone install a cng from amateur fuel pump will keep on running dry or it will be blocked at the end?
