you have to understand turbo application completely to be able to run it on n/a combination.
though i totally disagree with you did, but obviously you must had some financial constrants for doing this.
the problems isnt injectors the problem is less air, try the electronic supercharger. - this may not be a good solution either
best would be to buy all turbo parts and complete the factory engine setup
