Salam to all Pakwheelers
I wanted to ask is there any good electrician in Rawalpindi to properly check
1) wiring of the car.( short circuiting)
2) can do ground wiring-
3) can check the starting system whether its working optimum
(battery/alternator/starter).
4) can check coils and current to the spark plugs
5) Also the dash board brake lights and other lights go dim when i turn on head lamps or indicator.
the problem is that sometimes the car takes a long self to start and some times the car loses power even while its engine is hot running on cng. car is baleno 1998.
thanking you all in advance:)
