My CL-9 Is UK Import.
It Has The OEM Single Row Radiator & OEM Thermostat Which Activates At 78*C
(As I Faced Only Once Issue Of Heating)
Remember:
Radiator Is Clean, No Leaks, Flushed Properly, Used 25% Coolent & 75% Water.
Auto Fan Is Working Correct
From Then I Thought To Make Engine Cooling Syetem Better ..
Now Em Looking For A Performace Almuinum 2 row Radiator For It But Could Not Find Any Bolt On Radiator
On Second Note I Thought To Change The Current One With Japan Model OEM Radiator.
As One Of The Machinic Told Me That Japan Model Radiator Is Single Row But With Big Nozzle Hose
& Will Work Better Then The Current One Installed.(True?)
Does The Japan CL-9 Model & UK Model CL-9 Has Same Radiator Or Is There Any Differenace ?
(As Metioned Above)
I Have Also Bought The Mishimoto Racing Thermostat For It
Which Will Be Activated @ 68* C
OBX Radiator Hose Pipes So That The Cooling Systems Gets Better Then Before ..
Kindly Suggested Me For The Radiator Issue ..
Looking For Ur Feed Back.
