how to check thermostat working or not on vitz 2003
i hv a digital meter
start in the morning , open the radiator cap.. If you see the movement of Coolant... means Thermostate isnot working..
one more thing today i hv change my car fan to auto from direct if thermostat is not there can i drive this car not until get it installed
If Fan is direct. then Obviously there isnot thermostate..you can Drive without Thermostate more then 70% vehicle in Pakistan run without thermostate..but its harmful for you car Engine
How??????
The fan may be direct with the thermostat in place
yaar my question is i change the fan to auto mode but i m not sure thermostat present or not if thermostat is not there and the fan is on auto mode in this codition car is safe to drive or not
Pakistani mechanic First remove the Themromstate ,
